How nvurisrcbin decode multi stream
• Hardware Platform Jetson
• DeepStream Version 6.3
• JetPack Version 5.1.2
• TensorRT Version 8.5.2
• Issue Type: Question
I am using deepstream-test3 to connect with multi rtsp stream. But compare test3 with test1, it seems test3 doesn’t use h264-parser and nvv4l2-decoder. Does it mean for test3 it will not use “hardware accelerated decode on GPU”?
If so, how can I configure to use both nvurisrcbin and nvv4l2-decoder?
• TensorRT Version
no, nvurisrcbin encapsulates h264-parser and nvv4l2-decoder. HW decoder has a higher priority than SW decoder. nvurisrcbin will select HW decoder with priority. you can dump the media pipeline to check by this FAQ.
