Isaac Sim Version
[v] 4.0.0
Operating System
[v] Windows 11
GPU Information
- Model: RTX 4070ti
I have created a custom execution attribute in the script node and want to trigger it using an if-else statement.
How should I trigger the custom execution pin on the script node?
///////////////My code as below//////////////////
from omni.graph.action_core import get_interface
def setup(db: og.Database):
state = db.per_instance_state
state.index = 0
pass
def cleanup(db: og.Database):
pass
def compute(db: og.Database):
if state.index < 10:
get_interface().set_execution_enabled(“outputs:trigger”)
else:
get_interface().set_execution_enabled(“outputs:execOut”)
state.index += 1
return True
However, when I execute this code, the cmd reports an error as follows.
[Error] [omni.graph.core.plugin] /World/ActionGraph/script_node: [/World/ActionGraph] 2 activated outputs, only 1 is permitted per compute. [outputs:execOut,outputs:trigger]
Thank you so much for the help.
