How the hardware and compiler process the register dependency
Hello experts,
I have one question about the syncronization between load and register consumer instruction within one single thread. I found that there is no dependency barrier in some cases while others may have DEPBAR.LE being inserted by compiler. Could someone help explain it, thank you.
Will the hardware check the register dependency and guarantee the correctness?
When do we need the compiler to insert the explicit DEPBAR instruction?
case_1: no DEPBAR between LDG and IADD instructions:
    code for sm_52
            Function : _Z6vecAddPiS_S_i
    .headerflags    @"EF_CUDA_SM52 EF_CUDA_PTX_SM(EF_CUDA_SM52)"
        /* 0x001cfc00e22007f6 */
    /*0008*/                   MOV R1, c[0x0][0x20] ;                        /* 0x4c98078000870001 */
    /*0010*/                   S2R R0, SR_CTAID.X ;                          /* 0xf0c8000002570000 */
    /*0018*/                   S2R R2, SR_TID.X ;                            /* 0xf0c8000002170002 */
        /* 0x001fd842fec20ff1 */
    /*0028*/                   XMAD.MRG R3, R0.reuse, c[0x0] [0x8].H1, RZ ;  /* 0x4f107f8000270003 */
    /*0030*/                   XMAD R2, R0.reuse, c[0x0] [0x8], R2 ;         /* 0x4e00010000270002 */
    /*0038*/                   XMAD.PSL.CBCC R0, R0.H1, R3.H1, R2 ;          /* 0x5b30011800370000 */
        /* 0x001ff400fd4007ed */
    /*0048*/                   ISETP.GE.AND P0, PT, R0, c[0x0][0x158], PT ;  /* 0x4b6d038005670007 */
    /*0050*/                   NOP ;                                         /* 0x50b0000000070f00 */
    /*0058*/               @P0 EXIT ;                                        /* 0xe30000000000000f */
        /* 0x081fd800fea207f1 */
    /*0068*/                   SHL R6, R0.reuse, 0x2 ;                       /* 0x3848000000270006 */
    /*0070*/                   SHR R0, R0, 0x1e ;                            /* 0x3829000001e70000 */
    /*0078*/                   IADD R4.CC, R6.reuse, c[0x0][0x140] ;         /* 0x4c10800005070604 */
        /* 0x001fd800fe0207f2 */
    /*0088*/                   IADD.X R5, R0.reuse, c[0x0][0x144] ;          /* 0x4c10080005170005 */
    /*0090*/         {         IADD R2.CC, R6, c[0x0][0x148] ;               /* 0x4c10800005270602 */
    /*0098*/                   LDG.E R4, [R4]         }
        /* 0xeed4200000070404 */
        /* 0x001fd800f62007e2 */
    /*00a8*/                   IADD.X R3, R0, c[0x0][0x14c] ;                /* 0x4c10080005370003 */
    /*00b0*/                   LDG.E R2, [R2] ;                              /* 0xeed4200000070202 */
    /*00b8*/                   IADD R6.CC, R6, c[0x0][0x150] ;               /* 0x4c10800005470606 */
        /* 0x001fc420fe4007f7 */
    /*00c8*/                   IADD.X R7, R0, c[0x0][0x154] ;                /* 0x4c10080005570007 */
    /*00d0*/                   IADD R0, R2, R4 ;                             /* 0x5c10000000470200 */
    /*00d8*/                   STG.E [R6], R0 ;                              /* 0xeedc200000070600 */
        /* 0x001ffc00ffe007ea */
    /*00e8*/                   NOP ;                                         /* 0x50b0000000070f00 */
    /*00f0*/                   EXIT ;                                        /* 0xe30000000007000f */
    /*00f8*/                   BRA 0xf8 ;                                    /* 0xe2400fffff87000f */
case_2: DEPBAR.LE is inserted in the sass instructions
    code for sm_52
            Function : _Z8vadd_intPiPKiS_ii
    .headerflags    @"EF_CUDA_TEXMODE_UNIFIED EF_CUDA_64BIT_ADDRESS EF_CUDA_SM52 EF_CUDA_VIRTUAL_SM(EF_CUDA_SM52)"
        /* 0x001c4400fe0007f6 */
    /*0010*/                   MOV R2, c[0x0][0x140] ;                        /* 0x4c98078005070002 */
    /*0018*/                   S2R R19, SR_CTAID.X ;                          /* 0xf0c8000002570013 */
        /* 0x001fc400fe2007f2 */
    /*0028*/                   MOV R3, c[0x0][0x144] ;                        /* 0x4c98078005170003 */
    /*0030*/                   LDG.E.CI R0, [R2] ;                            /* 0xeed4a00000070200 */
    /*0038*/                   LDG.E.CI R5, [R2+0x4] ;                        /* 0xeed4a00000470205 */
        /* 0x001ec400fe2007b1 */
    /*0048*/                   LDG.E.CI R6, [R2+0x8] ;                        /* 0xeed4a00000870206 */
    /*0050*/                   LDG.E.CI R4, [R2+0xc] ;                        /* 0xeed4a00000c70204 */
    /*0058*/                   LDG.E.CI R7, [R2+0x10] ;                       /* 0xeed4a00001070207 */
        /* 0x001fc400f62007f1 */
    /*0068*/                   LDG.E.CI R8, [R2+0x14] ;                       /* 0xeed4a00001470208 */
    /*0070*/                   LDG.E.CI R9, [R2+0x18] ;                       /* 0xeed4a00001870209 */
    /*0078*/                   LDG.E.CI R10, [R2+0x1c] ;                      /* 0xeed4a00001c7020a */
    /*0088*/                   LDG.E.CI R11, [R2+0x20] ;                      /* 0xeed4a0000207020b */
    /*0090*/                   LDG.E.CI R12, [R2+0x24] ;                      /* 0xeed4a0000247020c */
    /*0098*/                   LDG.E.CI R13, [R2+0x28] ;                      /* 0xeed4a0000287020d */
    /*00a8*/                   LDG.E.CI R14, [R2+0x2c] ;                      /* 0xeed4a00002c7020e */
    /*00b0*/                   LDG.E.CI R15, [R2+0x30] ;                      /* 0xeed4a0000307020f */
    /*00b8*/                   LDG.E.CI R16, [R2+0x34] ;                      /* 0xeed4a00003470210 */
        /* 0x001fcc00362007b1 */
    /*00c8*/                   LDG.E.CI R17, [R2+0x38] ;                      /* 0xeed4a00003870211 */
    /*00d0*/                   LDG.E.CI R18, [R2+0x3c] ;                      /* 0xeed4a00003c70212 */
    /*00d8*/                   DEPBAR.LE SB5, 0x6 ;                           /* 0xf0f0000034670000 */
        /* 0x001f8400eac007f0 */
    /*00e8*/                   IADD3 R5, R6, R5, R0 ;                         /* 0x5cc0000000570605 */
    /*00f0*/                   S2R R0, SR_TID.X ;                             /* 0xf0c8000002170000 */
    /*00f8*/                   IADD3 R7, R7, R4, R5 ;                         /* 0x5cc0028000470707 */
        /* 0x001fd800fea20ff0 */
    /*0108*/                   XMAD.MRG R5, R19.reuse, c[0x0] [0x8].H1, RZ ;  /* 0x4f107f8000271305 */
    /*0110*/                   DEPBAR.LE SB5, 0x4 ;                           /* 0xf0f0000034470000 */
    /*0118*/                   IADD3 R8, R9, R8, R7 ;                         /* 0x5cc0038000870908 */
        /* 0x001fc400fec007f0 */
    /*0128*/                   IADD3 R10, R11, R10, R8 ;                      /* 0x5cc0040000a70b0a */
    /*0130*/                   DEPBAR.LE SB5, 0x2 ;                           /* 0xf0f0000034270000 */
    /*0138*/                   IADD3 R12, R13, R12, R10 ;                     /* 0x5cc0050000c70d0c */
        /* 0x001fd400fc2027f5 */
The reason is that the second code uses IADD3 with 3 source operands. SASS can only specify one source and one destination scoreboard per instruction. One source operand could be waited for by a previous instruction or generated by a fixed latency (arithmetic) instruction. But if you load two operands from memory, you need an additional dependency bar.
Volta onwards: The source operand scoreboard, an instruction is waiting for, is stored in bits 113-115, the destination operand score board in bits 110-112 and not shown in the mnemonic output.
For Maxwell 5.2: I think the instructions wait for the scoreboards in bits 51-53 and 54-56 bits.
Hi Curefab, thank you for the explaination.
SASS can only specify one source and one destination scoreboard per instruction. … But if you load two operands from memory, you need an additional dependency bar.
But in the first case, IADD R0, R2, R4 has two operands R2, R4 and both them are loaded from memory. Why there is no additional dependency bar?
I am not sure about the exact working of the scoreboard.
The numbers do not make full sense.
Also perhaps more than one load can be put onto a single scoreboard.
Perhaps somebody else knows more details or can link to some reverse engineering assembler or paper.
When disassembling, you can activate the register dependencies: I think it was possible with nvdisasm --print-life-ranges
Here you see some information about the encoding of the dependencies on Maxwell, how to set dependencies and wait for them:
Thank you Curefab.
I am going to be reading the part. Hope it can answer my question.
