How the set backwardCompatibilityCheckMode to be "disabled " permanately?
I think it is really stupid when you run isaacsim by the python scripts, and the backwardCompatibility checker Pop-ups and you need to click to close it every every time ! . I can set backwardCompatibilityCheckMode disabled in edit->preference->physics .
But when you run isaac sim by python scripts again , it comes back .
By the way the modify content in preference takes no effect in python script running isaacsim . Maybe you can do something to make it easier for users.
I try to config in omni.isaac.sim.python.kit and user.config.json , but takes no effect too.
Thank you very much if you could help me !
Hi @fzg7919
You can run the script or launch Isaac Sim from the command line with the following argument to disable the physics backward compatibility check
--/persistent/physics/backwardCompatibilityCheckMode=0
Thank you so much !
And I have found the way to save preference changes automatically - just set "[settings.app.settings]
persistent = true " in omni.isaac.sim.python.kit file .
