Hi, I works on a stereovision app and I have a problem with the sorting in a global function.
Without sorting the program runs without error. But with sorting I have a problem of memory stack and I don’t understand why.
This is my line, with dif a float * and window an integer
thrust::sort(thrust::seq, dif, dif + window);
In my main function I call with 70 blocks and 50 threads but I don’t think number have a link.
The one line of code that you have given is too little to help. Can you create a small/minimal example that demonstrates the problem?
Yes sorry, follow an exemple
__constant__ int widthWindow2 = 9;
__device__
void makeVector(float *mat, float *vec, int col, int x, int y) {
int ind = 0;
for (int i = x; i < x + widthWindow2; i++) {
for (int j = y; j < y + widthWindow2; j++) {
vec[ind] = mat[col * i + j];
ind++;
__global__
void computeSMAD2(int minX, float *d_mL, float *d_mR, float *dif, float *windowL, float *windowR, float *d_disparity, int colmLO, int colmL, int seachWindow) {
int mini;
int pOiX(threadIdx.x + minX); // + minX
int pOiY(blockIdx.x + minX);
int newPoIx(max(minX, pOiX - searchWindow));
int newPoIy(pOiY);
int minPoIx(newPoIx);
int smad = 0;
int bMax = (int)(correlationWindow / 2);
makeVector(d_mL, windowL, colmL, pOiY, pOiX); // ATTENTION ligne / colonne
makeVector(d_mR, windowR, colmL, newPoIy, newPoIx);
for (int h = 0; h < correlationWindow; h++) {
dif[h] = windowL[h] - windowR[h];
thrust::sort(thrust::seq, dif, dif + correlationWindow);
int median = dif[(correlationWindow - 1) / 2];
dif[h] = abs(dif[h] - median);
for (int i = 0; i <= bMax - 1; i++) {
smad = smad + pow(dif[i], 2);
mini = smad;
newPoIx++;
for (int i = newPoIx; i <= pOiX; i++) {
smad = 0;
makeVector(d_mR, windowR, colmL, newPoIy, i);
for (int j = 0; j <= bMax - 1; j++) {
if (smad < mini) {
smad = smad + pow(dif[j], 2);
else {
break;
if (smad < mini) {
mini = smad;
minPoIx = i;
int distance = pOiX - minPoIx;
d_disparity[colmLO * (pOiY - minX) + (pOiX - minX)] = ((255 / searchWindow) * distance);
Thank you
