Jetson Orin NX • DeepStream Version
7.0 • JetPack Version (valid for Jetson only)
JetPack 6.0 • TensorRT Version
TensorRT 8.6.2.3 • NVIDIA GPU Driver Version (valid for GPU only)
NVIDIA UNIX Open Kernel Module for aarch64 540.3.0 • Issue Type( questions, new requirements, bugs)
I wish to detect objects from RTSP source and create RTSP output, however it always come with “Stream format not found, dropping the frame”, then log “streaming stopped, reason not-negotiated (-4)”. Adapted from the official DeepStream example source30_1080p_dec_infer-resnet_tiled_display_int8.
We had solved this problem, but encountered another problem when we’re trying using our own model on detection. We changed .engine to our own, but it turned out
