I am creating a simple extension where I can print the coordinates of a cube on every frame while I can translate the cube. I thought I can do so by using Event streams. Any idea?
Hi @michael.alassaad. Can you describe a bit more why you would need an event stream for this? Are you moving the cube programmatically or interactively with a mouse?
Related topics
Topic | Replies | Views | Activity | |
Any Real CUDA Application extensively using Streams | 0 | 3050 | January 29, 2009 | |
Special case overlapping execution and transfer times with streams | 3 | 1450 | April 2, 2009 | |
Cuda stream | 1 | 634 | May 1, 2021 | |
Stream Data | 1 | 1578 | June 9, 2011 | |
streaming data to the GPU | 1 | 5452 | January 29, 2010 | |
Streaming video from GPU separate of the O/S desktop | 0 | 554 | December 19, 2016 | |
CUDA Stream | 1 | 334 | October 16, 2020 | |
External Notifications into CUDA Asynchronous Loop | 1 | 577 | August 5, 2016 | |
Explainer: What Is Stream Processing? | 1 | 208 | March 1, 2024 | |
Explainer: What Is Stream Processing? | 1 | 195 | March 7, 2024 |
