I´m trying to get the value of “network-type” parameter set in “config_primary_gie.txt” from within deepstream-app code, but I don´t find the way to do it. I found there is a structure called “NvDsGieConfig”. However, it hasn´t got any structure inside which can be used to get network-type value.
That code is not present in deepstream-app as that is a parameter for nvinfer.
You can access it in gst-plugins/gst-nvinfer/gstnvinfer_property_parser.h
