I need to use the tensor output of nvinfer plugin in python code (preferably as np.ndarray).
based on deepstream_infer_tensor_meta_test.cpp’s pgie_pad_buffer_probe function, I wrote a python function that will get the tensor-meta memory address. Here is the function:
import pyds
import pycuda.driver as cuda
import ctypes
ctypes.pythonapi.PyCapsule_GetPointer.restype = ctypes.c_void_p
ctypes.pythonapi.PyCapsule_GetPointer.argtypes = [ctypes.py_object, ctypes.c_char_p]
def extract_tensor_meta(batch_meta: pyds.NvDsBatchMeta):
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
l_user = frame_meta.frame_user_meta_list
while l_user is not None:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
break
meta_type = user_meta.base_meta.meta_type
if meta_type == pyds.NVDSINFER_TENSOR_OUTPUT_META:
meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
for i in range(meta.num_output_layers):
mem_add = ctypes.pythonapi.PyCapsule_GetPointer(
meta.out_buf_ptrs_host, None)
cuda.memcpy_dtoh(mem_add + i, 0)
try:
l_user = l_user.next
break
try:
l_frame = l_frame.next
break
But the cuda.memcpy line throws
TypeError: a bytes-like object is required, not 'int'
Prior to converting the meta.out_buf_ptrs_host to memory address I simply tried
cuda.memcpy_dtoh(meta.out_buf_ptrs_host[i], meta.out_buf_ptrs_dev[i])
But I encountered:
TypeError: 'PyCapsule' object is not subscriptable
I also tried to convert the memory address into a python object by dereferencing the memory address with no success.
My setup:
Hardware Platform: GPU
DeepStream Version: 5.1
TensorRT Version: 7.2.1.6
NVIDIA GPU Driver Version: 460.73.01
Reference for pycuda.driver.memcpy: Device Interface - pycuda 2022.1 documentation
deepstream_infer_tensor_meta_test.cpp address:
/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/deepstream_infer_tensor_meta_test.cpp
Could you please help me convert the nvinfer tensor output into a python object?
Thanks a lot!
