How to Activate DLA, PVA, and Other Engines on Jetson AGX Orin SOM
I’m using the Jetson AGX Orin Industrial SOM with a custom board, and I have also tried the EVKit. I want to use engines such as DLA0, DLA1, PVA, NVDEC, NVENC, NVJPG0, and NVJPG1.
I have installed JetPack 5.1.2 via the SDK Manager and have installed all the necessary runtime and SDK components.
I have run Jetson Inference with DetectNet and other models, but the engines are not active.
I am using TensorRT and CUDA. Could you please guide me on how to activate or enable these engines?
Regards,
Parashuram
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
