i configured the 40-pins according to this link.:‘Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
Run “sudo /opt/nvidia/jetson-io/jetson-io.py”
Configure Jetson 40pin header
select spi1 , save and reboot
But the spi’s config lost after reboot.
What do you mean SPI’s config lost?
How do check the SPI configure lost???
run jetson-io.py again, the ‘spi’ is unselected.
and the orin spi clock isn’t wave…
Did you verify the loopback test?
system
Closed
September 28, 2022, 2:48am
10
