How to add 120Hz frame-rate on Jetson TX1 ?
Adding 1920x1080 @ 120Hz on Jetson TX1 throws error.
Steps followed:
  1. cvt 1920 1080 120
Modeline “1920x1080_120”
  1. xrandr --newmode “1920x1080_120”
X Error of failed request : Basnmae (named color or font does not exist)
Major opcode of failed request : 140 (RANDR)
Major opcode of failed request : 16 (RRCreateMode)
Serial number of failed request ; 20
Current serial number in output stream : 20
hello muttu2704,
may I know what’s your 120Hz frame-rate use-case, is it display or sensor outputting?
if you’re working with 1920x1080@120-fps sensor, could you please share more details. thanks
(1) could you please share which sensor driver you’re working with.
(2) following by (1), please verify that signaling outputting is correct
hello JerryChang,
Yes, it is for display outputting from HDMI of Jetson TX1.
Our Xorg driver would not allow user to define their own mode. All modes are available only when EDID from your monitor has it on list.
hello WayneWWW,
I connect board to HDMI input of TV, and TV supports 1920x1080 @120Hz.
In this condition, if run:
$ xrandr
120Hz is not listed.
TX1 does not support such frame rate. Currently, I guess it is just up to 60fps.
Okay, Thanks WayneWWW for the info.
