I followed the tips from chatgpt,but it did not work:
Enhanced Guide for NVIDIA Jetson Kernel Update
Step 1: Setup and Download Kernel Sources
- Install Required Packages:
bash
复制代码
sudo apt-get update
sudo apt-get install build-essential bc git libncurses5-dev bison flex libssl-dev
- Download NVIDIA Jetson Kernel Sources:
bash
复制代码
git clone --depth 1 -b tegra-l4t-r32.5.1 https://github.com/nvidia/linux-nvidia.git
cd linux-nvidia
3.Note*: Ensure you use the correct branch/tag corresponding to your L4T version.
Step 2: Extract and Modify the Kernel Configuration
- Extract Current Configuration:
bash
复制代码
zcat /proc/config.gz > .config
- Copy Configuration to Source Directory:
bash
复制代码
cp .config linux-nvidia/
cd linux-nvidia
- Modify Kernel Configuration:
bash
复制代码
make menuconfig
Make your necessary changes (e.g., enabling BPF_SYSCALL
4. Save the Modified Configuration:
bash
复制代码
cp .config .config.modified
Step 3: Build the Kernel
- Set Up the Environment:
bash
复制代码
export ARCH=arm64
export CROSS_COMPILE=aarch64-linux-gnu-
- Compile the Kernel:
bash
复制代码
make -j$(nproc) Image
make -j$(nproc) modules
make -j$(nproc) dtbs
- Install Kernel Modules:
bash
复制代码
sudo make modules_install INSTALL_MOD_PATH=../kernel_modules
Step 4: Deploy the Kernel and Modules
- Copy the Kernel Image:
bash
复制代码
sudo cp arch/arm64/boot/Image /boot/Image
- Copy the Device Tree Blobs (if necessary):
bash
复制代码
sudo cp arch/arm64/boot/dts/*.dtb /boot/
- Copy the Kernel Modules:
bash
复制代码
sudo cp -r ../kernel_modules/lib/modules/$(uname -r)/kernel /lib/modules/$(uname -r)/
Step 5: Update Bootloader (if needed)
Ensure the bootloader (U-Boot) is configured to use the new kernel image if necessary.
Step 6: Reboot and Verify
- Reboot the System:
bash
复制代码
sudo reboot
- Verify the New Configuration:
bash
复制代码
uname -r
zgrep 'BPF' /proc/config.gz
“bpftool feature” command still shows “bpf() syscall is NOT available”,i do have changed the kernel config and set CONFIG_BPF_SYSCALL=y
