How to add custom attributes to video frames in the queue
jetpack 4.6.1
xavier nx
cuda arch 7.2.2
cuda 10.2
opencv 4.1.1
TensorRt 8.2.1.8
cudnn 8.2.1.32
deepstream-app version 6.0.1
DeepstreamSDK 6.0.1
deepstram-python 1.1.1
I need to add a queue after streammux, get the real-time latitude and longitude in this queue and add the latitude and longitude to the data of the video frame, to ensure that when the recognition result is obtained at the end, the obtained latitude and longitude is the relatively accurate latitude and longitude of the current frame
Is the “latitude and longitude” for the whole frame or for some objects? You can add the "“latitude and longitude” by customizing your own NVIDIA DeepStream SDK API Reference: _NvDsUserMeta Struct Reference | NVIDIA Docs with NVIDIA DeepStream SDK API Reference: _NvDsFrameMeta Struct Reference | NVIDIA Docs or NVIDIA DeepStream SDK API Reference: _NvDsObjectMeta Struct Reference | NVIDIA Docs according to your scenario.
There is NvDsUserMeta customization sample in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-gst-metadata-test
Does it mean that you can only write c++ classes first and then call them on python, and you can’t add them directly through python
Python is just a script language, the binary under it can be generated by c/c++ or any other language. You can customize user meta binding. https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/bindings/CUSTOMUSERMETAGUIDE.md
When I use the camera, the frame_num and batch_id obtained through the frame meta are always 0. Is this because of this design, or is it because my configuration is wrong?
Where did you get the number? After or inside which plugin?
