GLib-GObject-WARNING **: g_object_set_is_valid_property: object class 'GstFileSink' has no property named 'output-file'
ERROR from element nvvideo-renderer: No file name specified for writing
For running deepstream-test4, you have to study the code and integrate ‘Encode + File Save’ into the sample. Maybe you can try deepstream-test5 to simply enable it in config file.
