I have learned how to import and build a robot model to add physical properties, joint connections and drives through official documents. How should kinematics and dynamics be added further。Are there any relevant tutorials or cases for reference?
Kinematics: You can define the kinematics of your robot by setting up the joint connections in your robot model. This includes defining the type of joint (revolute, prismatic, etc.), the axis of rotation or translation, and the parent-child link relationships. This is typically done in the URDF or SDF file of your robot model.
Dynamics: You can define the dynamics of your robot by setting up the physical properties of the links in your robot model. This includes defining the mass, inertia, and center of mass of each link. This is also typically done in the URDF or SDF file of your robot model.
Drives: You can define the drives of your robot by setting up the joint controllers in your robot model. This includes defining the type of controller (position, velocity, etc.), the control gains, and the control limits. This is typically done in the configuration file of your robot model.
You can find some basic information here:
https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_physics.html#overview
You can also refer to the URDF and SDF specifications for more information on how to define the kinematics and dynamics of your robot model:
- URDF Specification: urdf/XML - ROS Wiki
- SDF Specification: SDFormat Specification
