• Hardware Platform (Jetson / GPU) - Jetson Nano • DeepStream Version - 6.0 • JetPack Version (valid for Jetson only) - 4.6.1-b110 • TensorRT Version - 8.2.1.8 • NVIDIA GPU Driver Version (valid for GPU only) - 10.2 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I need to add motion detection to record and store in .mp4 format in deepstream python?
you can modify the configuration file deepstream_app_config.txt to save mp4, please refer to opt\nvidia\deepstream\deepstream-6.1.1\samples\configs\deepstream-app\source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
like this:
using tee and valve component with dynamic pipeline, i can able pause the recording using probe function but the empty buffers are there in recorded video,
example, I skip the frame between 20 to 30 seconds, in recorded video,
in recorded video there is an empty buffers between 20 to 30 seconds
there is no ready-made deepstream sample, please refer to gstreamer code samples.
