Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
What’s the eeprom.json file? Could you elucidate what you are trying to do? If you can point out the related document you found, it will be more clear. Thanks.
I checked internally and realized that you have other support channel.
The question you asked isn’t covered in devzone materials/scopes so please contact with your nvidia rep and use the support channel for it. Thanks.
