How to add new V4L2_CID?
I develop camera driver in Jetson AGX Orin.
I could send V4L2_CID_FRAME_SYNC by VIDIOC_S_CTRL from application, and our camera driver could get V4L2_CID_FRAME_SYNC in v4l2_ctrl_ops.s_ctrl function(cam_s_ctrl).
My user application:
enum {
	V4L2_CID_FACEDETECT = (V4L2_CID_AUTO_FOCUS_RANGE+1),
	V4L2_CID_FACEMARK,
	V4L2_CID_SMILEDETECT,
	V4L2_GET_FACEINFO,
	V4L2_CID_ROI_WINDOW,
	V4L2_CID_ROI_FOCUS,
	V4L2_CID_ROI_EXPOSURE,
	V4L2_CID_TRIGGER_FOCUS,
	V4L2_CID_HDR,
	V4L2_CID_COLORKILL,
	V4L2_CID_FRAME_SYNC,
	V4L2_CID_CUSTOM_EXPOSURE_AUTO,
	V4L2_CID_CUSTOM_FLASH_STROBE,
	V4L2_CID_DENOISE,
	V4L2_CID_GRAYSCALE,
	V4L2_CID_LSCMODE,
	V4L2_CID_FOCUS_WINDOW,
	V4L2_CID_EXPOSURE_COMPENSATION,
struct v4l2_control s_ctrl;
s_ctrl.id = V4L2_CID_FRAME_SYNC;
s_ctrl.value = 0x1;
V4L2_IOCTL( pDevice, VIDIOC_S_CTRL, &s_ctrl )
Camera driver:
static const struct v4l2_ctrl_ops cam_ctrl_ops = {
.g_volatile_ctrl = cam_g_volatile_ctrl,
.s_ctrl = cam_s_ctrl,
static int cam_s_ctrl(struct v4l2_ctrl *ctrl)
if(ctrl->id == V4L2_CID_FRAME_SYNC) do_cam_frame_sync;
I want add new V4L2_CID_NEW_ITEAM, but it can’t call into our v4l2_ctrl_ops.s_ctrl function(cam_s_ctrl), and v4l2_ctrl_find() get ref=NULL.
Do I missing some setting for add new V4L2_CID?
enum {
	V4L2_CID_FACEMARK,
	V4L2_GET_FACEINFO,
	V4L2_CID_ROI_FOCUS,
	V4L2_CID_HDR,
	V4L2_CID_COLORKILL,
	V4L2_CID_DENOISE,
	V4L2_CID_GRAYSCALE,
	V4L2_CID_LSCMODE,
	V4L2_CID_NEW_ITEAM, /* add this new CID */
s_ctrl.id = V4L2_CID_NEW_ITEAM;
s_ctrl.value = 0x1;
dmesg log:
[ 1350.756153] videodev: v4l2_ioctl:  FILE:/v4l2-dev.c,FUNC:v4l2_ioctl(cmd=0xC008561C),LINE:358,cmd=VIDIOC_S_CTRL
[ 1350.756163]  FILE:/v4l2-ioctl.c,FUNC:v4l_s_ctrl(),LINE:2327
[ 1350.756168]  FILE:/v4l2-ctrls.c,FUNC:find_ref_lock(id=0x9A0932),LINE:2486
[ 1350.756170]  FILE:/v4l2-ctrls.c,FUNC:find_ref(id=0x9A0932),LINE:2441
[ 1350.756174]  hdl->cached==0x0000000046aedc50, hdl->cached->ctrl->id=0x9A092A
[ 1350.756177]  bucket(0x3), hdl->nr_of_buckets(0x5) LINE:2453
[ 1350.756180]  ref->ctrl->id(0x9A2034), id(0x9A0932), hdl->buckets=00000000d5823dc0 --LINE:2463
[ 1350.756182]  ref->ctrl->id(0x9A2034), id(0x9A0932)
[ 1350.756185]  ref->ctrl->id(0x9A206B), id(0x9A0932)
[ 1350.756187]  ref->ctrl->id(0x9A2066), id(0x9A0932)
[ 1350.756189]  ref->ctrl->id(0x9A092D), id(0x9A0932)
[ 1350.756191]  ref->ctrl->id(0x98091B), id(0x9A0932)
[ 1350.756193]  ref->ctrl->id(0x98090C), id(0x9A0932)
[ 1350.756196]  ref->ctrl->id(0x980902), id(0x9A0932)
[ 1350.756198]  ref->ctrl->id(0x980001), id(0x9A0932)
[ 1350.756200]  ref=NULL ++LINE:2472
[ 1350.756203]  FILE:/v4l2-ctrls.c,FUNC:v4l2_ctrl_find(id=0x9A0932),LINE:2500
[ 1350.756204]  ref=NULL, id=0x9A0932
Using tegracam_ctrl_ops to implement it. You should be able reference to the ov5693.c to know the detail.
It is same the Configuring Controls in Sensor Software Driver Programming online documents?
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html#configuring-controls
Looks like it’s the older version and yes your can reference to nv_imx185_v1.c
Have you any document to introduce the new version tegracam_ctrl_ops to ov5693.cc?
Sorry to tell don’t have document for it. But you can check the source code to know the detail.
