How to add objeClassname in eventmsg_payload,cpp for libnvds_msgconv.so
eventmsg_payload.cpp:308:65: error: ‘NvDsEventMsgMeta’ {aka ‘struct NvDsEventMsgMeta’} has no member named ‘objclassname’
308 | json_object_set_string_member (objectObj,“objclassname”,meta->objclassname);
I am attempting to add objclassname in eventmsg_payload.cpp in generate_object_object for my Kafka pipeline, but when I try to build libnvds_msgconv.so, I get an error. I am also modifying eventmsg_payload. to add json_object_set_string_member (objectObj,“objclassname”,meta->objclassname);
• DeepStream Version
• TensorRT Version
Hardware Platform (Jetson / GPU):- GPU
• DeepStream Version 6.3
• TensorRT Version 8.6.1.6
• NVIDIA GPU Driver Version (valid for GPU only) 12.1
using deepstream kafka python
the error is clear, NvDsEventMsgMeta has no objclassname property. can you use objClassId instead?
yes i am using objclassid and it work but i want the object detection class name pass through Kafka pipeline
plesse refer to this topic for How to add custom data.
