Hi!
I need to add a led to show the sata hard driver status.I found some functions in driver/ata/libahci.c about led.
But I don’t know how to link a led in device tree.So could you kindly tell me how to do?
static void ahci_sw_activity_blink(unsigned long arg)
struct ata_link *link = (struct ata_link *)arg;
struct ata_port *ap = link->ap;
struct ahci_port_priv *pp = ap->private_data;
struct ahci_em_priv *emp = &pp->em_priv[link->pmp];
unsigned long led_message = emp->led_state;
u32 activity_led_state;
unsigned long flags;
led_message &= EM_MSG_LED_VALUE;
led_message |= ap->port_no | (link->pmp << 8);
/* check to see if we've had activity. If so,
* toggle state of LED and reset timer. If not,
* turn LED to desired idle state.
spin_lock_irqsave(ap->lock, flags);
if (emp->saved_activity != emp->activity) {
emp->saved_activity = emp->activity;
/* get the current LED state */
activity_led_state = led_message & EM_MSG_LED_VALUE_ON;
if (activity_led_state)
activity_led_state = 0;
else
activity_led_state = 1;
/* clear old state */
led_message &= ~EM_MSG_LED_VALUE_ACTIVITY;
/* toggle state */
led_message |= (activity_led_state << 16);
mod_timer(&emp->timer, jiffies + msecs_to_jiffies(100));
} else {
/* switch to idle */
if (emp->blink_policy == BLINK_OFF)
led_message |= (1 << 16);
spin_unlock_irqrestore(ap->lock, flags);
ap->ops->transmit_led_message(ap, led_message, 4);
static void ahci_init_sw_activity(struct ata_link *link)
/* init activity stats, setup timer */
emp->saved_activity = emp->activity = 0;
setup_timer(&emp->timer, ahci_sw_activity_blink, (unsigned long)link);
/* check our blink policy and set flag for link if it's enabled */
if (emp->blink_policy)
link->flags |= ATA_LFLAG_SW_ACTIVITY;
int ahci_reset_em(struct ata_host *host)
struct ahci_host_priv *hpriv = host->private_data;
void __iomem *mmio = hpriv->mmio;
u32 em_ctl;
em_ctl = readl(mmio + HOST_EM_CTL);
if ((em_ctl & EM_CTL_TM) || (em_ctl & EM_CTL_RST))
return -EINVAL;
writel(em_ctl | EM_CTL_RST, mmio + HOST_EM_CTL);
return 0;
EXPORT_SYMBOL_GPL(ahci_reset_em);
static ssize_t ahci_transmit_led_message(struct ata_port *ap, u32 state,
ssize_t size)
struct ahci_host_priv *hpriv = ap->host->private_data;
u32 em_ctl;
u32 message[] = {0, 0};
int pmp;
struct ahci_em_priv *emp;
/* get the slot number from the message */
pmp = (state & EM_MSG_LED_PMP_SLOT) >> 8;
if (pmp < EM_MAX_SLOTS)
emp = &pp->em_priv[pmp];
else
return -EINVAL;
ahci_rpm_get_port(ap);
* if we are still busy transmitting a previous message,
* do not allow
if (em_ctl & EM_CTL_TM) {
ahci_rpm_put_port(ap);
return -EBUSY;
if (hpriv->em_msg_type & EM_MSG_TYPE_LED) {
* create message header - this is all zero except for
* the message size, which is 4 bytes.
message[0] |= (4 << 8);
/* ignore 0:4 of byte zero, fill in port info yourself */
message[1] = ((state & ~EM_MSG_LED_HBA_PORT) | ap->port_no);
/* write message to EM_LOC */
writel(message[0], mmio + hpriv->em_loc);
writel(message[1], mmio + hpriv->em_loc+4);
* tell hardware to transmit the message
writel(em_ctl | EM_CTL_TM, mmio + HOST_EM_CTL);
/* save off new led state for port/slot */
emp->led_state = state;
return size;
static ssize_t ahci_led_show(struct ata_port *ap, char *buf)
struct ata_link *link;
int rc = 0;
ata_for_each_link(link, ap, EDGE) {
rc += sprintf(buf, "%lx\n", emp->led_state);
return rc;
static ssize_t ahci_led_store(struct ata_port *ap, const char *buf,
size_t size)
unsigned int state;
int pmp;
if (kstrtouint(buf, 0, &state) < 0)
return -EINVAL;
else
return -EINVAL;
/* mask off the activity bits if we are in sw_activity
* mode, user should turn off sw_activity before setting
* activity led through em_message
state &= ~EM_MSG_LED_VALUE_ACTIVITY;
return ap->ops->transmit_led_message(ap, state, size);
