How to adjust current nvenc max rate
We use follow method to configure venc to max rate.
My question is is there any tools just like jetson_clocks.sh to enable venc to max performance. As the result, the max rate of vnec will updated and can echo this new max rate to nvenc/rate.
That means how can we enable venc to work with the max rate over than current value 883200000.
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvenc/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvenc/state
cho 883200000 > /sys/kernel/debug/bpmp/debug/clk/nvenc/rate
/sys/kernel/debug/bpmp/debug/clk/nvenc# cat max_rate
883200000
/sys/kernel/debug/bpmp/debug/clk/nvenc# cat min_rate
115200000
/sys/kernel/debug/bpmp/debug/clk/nvenc# cat rate
883200000
If you use gstreamer, please set the property in nvv4l2h264enc or nvv4l2h265enc:
  maxperf-enable      : Enable or Disable Max Performance mode
                        flags: readable, writable, changeable only in NULL or READY state
                        Boolean. Default: false
If you use jetson_multimedia_api, please set option in 01_video_encode:
        --max-perf            Enable maximum Performance
DaneLLL, thanks for your replay, can we adjust max_rate over than current value 883200000?
No, it is limitation of the hardware engine.
