I’m not clearly understand the tuning steps in the guide book.
Is that means we have to do the MIPI calibration first, and after we get the register from the calibration debug report then using “devmem2” do the signal driven strength right?
If that so, may I ask how to do the MIPI calibration correctly or how to get the DSI register properly?
Appreciated for any help.
devmem2 is the tool for implementing the setting command, even the calibration is done with it. Please read the ‘Example of Devmem2 usage’ in guide for details, and you can find the related registers in TRM.
Hi Trumany,
I followed document to R/W register but still not work.
Such as DIS base address:15300000
Register “DSI_PAD_CONTROL_2_0” offset:0x51
Command: sudo devmem2 0x15300051
but it feedback error information as below:
/dev/mem opened.
Memory mapped at[ 6952.142221] Unhandled fault: alignment fault (0x92000021) at 0x0000007f891f5144 address 0x7f891f5000.
Bus error (core dumped)
Could you help me to check this error information?
We try to use 0x15880051 and we got the same fault information as below:
/dev/mem opened.
Memory mapped at[ 1480.809611] Unhandled fault: alignment fault (0x92000021) at 0x0000007f91063051 address 0x7f91063000.
