I’m evaluating DRIVE AGX PEGASUS (only with iGPU) in the viewpoint of performance and determinism.
Would you introduce which document explains the following items?
Do Tegra CPU and Tegra iGPU share the same system LPDDR4?
If yes for No. 1, when does the GPU driver allocate/deallocate the memory?
E.g., allocate at system startup and never deallocate until system shutdown.
