Hi everyone,
I’m trying to adapt a processing function using cuTensor
to perform conditional operations, but I’m struggling with how to implement the conditional part in my code. In the original code (shown below), I perform a multiplication and then check a condition to adjust the values of the tensor elements:
Original Code:
void Products::enb_emissivity_function(float* ndvi, float* lai, float* enb_emissivity)
for (int i = 0; i < this->height_band * this->width_band; i++)
enb_emissivity[i] = 0.97 + 0.0033 * lai[i];
if ((ndvi[i] < 0) || (lai[i] > 2.99))
enb_emissivity[i] = 0.98;
I’m trying to adapt this function using cuTensor
, but I’m unsure how to apply the conditional operation (as shown above) after executing the multiplication. Here’s the adapted code I have so far:
Adapted Code:
void Products::enb_emissivity_function(float* ndvi_d, float* lai_d, float* enb_d, float* only1_d)
float pos097 = 0.97;
float pos0033 = 0.033;
// tensor_plan_binary_add performs: enb_d = 0.97 * only1_d + 0.0033 * lai_d;
// createBinary(tensor_plan_binary_add, CUTENSOR_OP_IDENTITY, CUTENSOR_OP_IDENTITY, CUTENSOR_OP_ADD);
HANDLE_CUTENSOR_ERROR(cutensorElementwiseBinaryExecute(tensors.handle, tensors.tensor_plan_binary_add, (void *)&pos097, only1_d, (void *)&pos0033, lai_d, enb_d, tensors.stream));
// How can I implement the following condition using cuTensor/cuBLAS?
// if ((ndvi_d[i] < 0) || (lai_d[i] > 2.99))
// enb_d[i] = 0.98;
HANDLE_ERROR(cudaMemcpy(enb_emissivity, enb_d, sizeof(float) * this->height_band * this->width_band, cudaMemcpyDeviceToHost));
My question is: Is there a way to perform conditional operations directly using cuTensor
or cuBLAS
, or do I need to write a custom CUDA kernel for this conditional logic?
Any tips or suggestions would be greatly appreciated. Thanks in advance!
