How to assign custom source-id to buffer?
• DeepStream Version 6.4
I’d like to do exactly the same thing as in this post from a Deepstream python sample :
Post 277852
Could you provide a way to do this?
• TensorRT Version
  • RTX 3060
  • DS 6.4
  • Using Docker
  • NVIDIA-SMI 535.161.07
I want to do the exact same thing than what is done for Post 277852 for Python Deepstream sample deepstream_test_3.py
Cheers
you can use the similar method. Here you can set a custom name to padname.
I don’t want to update the padname.
I want to update source_id. The value is currently 0;1;2;3;… It is not something like "sink_%u" %i
as said in the topic mentioned in the issue description, framemeta’s source_id is set in nvstreammux plugin. the index in padname will be regarded as souce_id in nvstreammux .
