how to avoid the global memory latency in selection
Dear All,
I try to select, nforc, datas from a array, w(ndata) if its element is larger than the value, tol,
my code is (in which 256 threads are used):
       real*8, device :: w(n), blk(100*256)
         isub=threadidx%x
        ipx=(isub-1)*100
         iforc=0
         do i=isub,ndata,256
            if(w(il).gt.tol) then
               iforc=iforc+1
               blk(ipx+ijforc)=i
              endif
          enddo
          nsav(isub)=iforc
          call syncthreads()
However, I found most time used is the statement
blk(ipx+ijforc)=i
I seems the problem is due to the global memory latency.
Does anyone have a better solution ?
Thanks in advance
Minghui
Hi yangmh,
It’s not the latency. Rather, it’s that the data is not contiguous across threads in a warp leading to memory divergence. To fix, you’ll need to change your algorithm so that blk can be accessed using “i” instead of “ipx+ijforce”.
Hope this helps,
Mat
Hi, Mat,
Thanks for your help !
That means, If the array w(ndata) is divided into several parts, each of them is treated in shared memory, the memory divergence could be avoided ?
Minghui
