Based on the provided context, it appears that you are attempting to migrate your current environment system to another system using the Jetson Orin Nano. You have used the l4t_backup_restore.sh script to create a backup of your system and are now trying to restore it to the new system.
However, you are encountering an error when trying to attach to the device /dev/nvme0n1. This device is functioning normally and was originally capable of booting up normally.
To analyze this error, let’s break down the log output:
- The script is trying to create a symbolic link to
/proc/self/fd as /dev/fd.
- It then tries to mount the
/home/username/test1/Linux_for_Tegra/tools/backup_restore directory to /mnt.
- The script then tries to restore the partitions using the
nvrestore_partitions.sh script.
- The script uses the default
nvpartitionmap.txt file as the index file.
- The script then tries to copy 400 records from the backup to the new system, but encounters an error when trying to attach to
/dev/nvme0n1.
The error message “Error: Unable to partprobe /dev/nvme0n1” suggests that the script is unable to probe the partitions on the /dev/nvme0n1 device. This could be due to a variety of reasons, such as:
- The device is not properly connected or configured.
- The device is not recognized by the system.
- There is a conflict with another device or partition.
To troubleshoot this issue, you can try the following:
- Verify that the
/dev/nvme0n1 device is properly connected and configured.
- Check the system logs to see if there are any error messages related to the device.
- Try running the
partprobe command manually to see if it returns any errors.
- Check the
nvpartitionmap.txt file to ensure that it is correctly configured for the new system.
It’s also worth noting that the l4t_backup_restore.sh script is a complex script that performs a variety of tasks, including creating a backup of the system, restoring the partitions, and configuring the system. If you are experiencing issues with this script, it may be helpful to try breaking it down into smaller tasks to see where the error is occurring.
In comparison to other Jetson modules, the Jetson Orin Nano has a similar architecture and uses the same l4t_backup_restore.sh script for backup and restore operations. However, the specific error message and log output may vary depending on the module and system configuration.
In terms of HDMI support, the Jetson Orin NX and Nano modules support HDMI in addition to DP. To customize the carrier baseboard to HDMI, you can use the p3509-a02-p3767-0000.conf config file to flash the board.
Overall, the error message and log output suggest that there is an issue with the /dev/nvme0n1 device that is preventing the script from completing the restore operation. Further troubleshooting and debugging may be necessary to resolve this issue.
