Based on the provided context, it appears that you are experiencing an issue with flashing a system image from a 64GB Jetson AGX Orin development kit to a 32GB module. The error message suggests that the partition UUID is not correct.
To resolve this issue, you need to understand how the partition configuration works on Jetson devices. The partition configuration is described in the partition_config.txt file, which is used by the flash.sh script to flash the images to the device.
When you backup the system partition from a 64GB development kit, the resulting system64g.img file contains the partition configuration for a 64GB device. However, when you flash this image to a 32GB module, the partition configuration is not compatible, resulting in the error message.
To resolve this issue, you need to modify the partition configuration to match the 32GB module. You can do this by editing the partition_config.txt file and updating the partition sizes and UUIDs to match the 32GB module.
Here are the steps to follow:
- Extract the
partition_config.txt file from the system64g.img file using the flash.sh script with the -x option:
$ sudo ./flash.sh -x system64g.img partition_config.txt
- Edit the
partition_config.txt file to update the partition sizes and UUIDs to match the 32GB module. You can use a text editor or a tool like uuidgen to generate new UUIDs.
- Save the updated
partition_config.txt file.
- Flash the updated
partition_config.txt file to the 32GB module using the flash.sh script:
$ sudo ./flash.sh -u <pkc_keyfile> -v <sbk_keyfile> jetson-agx-orin-devkit internal
Replace <pkc_keyfile> and <sbk_keyfile> with the actual file names and paths.
By updating the partition configuration to match the 32GB module, you should be able to resolve the issue and successfully flash the system image to the device.
Note that if you are using a different Jetson module or development kit, the partition configuration may vary. It is essential to consult the Jetson Linux documentation and the specific device’s documentation to ensure that you are using the correct partition configuration.
