How to Boot from NVMe SSD?
If rootfs from SSD is mounted, you will see SD drive on desktop (Ubuntu gives SD icon to eMMC).
systemd-analize result attached.
Now we need to find how to load new kernel from SSD with flashed kernel’s kexec :).
it is really works :)
Thank a lot , @crazy_yorick
3 posts were split to a new topic: Does the Nvidia Xavier support NVME GEN4 SSD?
Can some one from Nvidia please confirm/provide the supported way of doing this?
Thank you.
After reflashing to JetPack 4.4 DP I had time to play with booting from SSD again and here are some remarks. Because forum fobids sharing archives with scripts, formated text will be included.
  1. I added conditional start for service on /etc/setssdroot.conf (on mmcblk0p1) availability. To mount rootfs from eMMC, file /etc/setssdroot.conf on mmcblk0p1 should be deleted.
    setssdroot.service:
[Unit]
Description=Change rootfs to SSD in M.2 key M slot (nvme0n1p1)
DefaultDependencies=no
Conflicts=shutdown.target
After=systemd-remount-fs.service
Before=local-fs-pre.target local-fs.target shutdown.target
Wants=local-fs-pre.target
ConditionPathExists=/dev/nvme0n1p1
ConditionPathExists=/etc/setssdroot.conf
ConditionVirtualization=!container
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/sbin/setssdroot.sh
[Install]
WantedBy=default.target
  1. setssdroot.service and setssdroot.sh should be on both mmcblk0p1 and nvme0n1p1 else service report error to journal, still switching rootfs.
  2. At JetPack 4.4 propoused to install new kernels and modules with deb packet. One should remember, that after installation, kernel, initrd and modules to rootfs switched to SSD would be placed on /boot/* and /lib/modules/[kernel name]/ on SSD and should manualy be copied to same folders on mmcblk0p1. Because Image and initrd, located in mmcblk0p1 /boot folder, pointed by /boot/extlinux/extlinux.conf data in mmcblk0p1, is booting with CBoot. If modules version in initrd on mmcblk0p1 and /lib/modules/[kernel name]/ on SSD will be different, modules load will be tainted.
So, step by step guid will be the following:
  • Flash Xavier with rootfs on eMMC (default with SDKManager)
  • Install default software, that will be needed on main (SSD) and restoration (eMMC) systems.
  • Copy rootfs to SSD.
#!/bin/bash
sudo mount /dev/nvme0n1p1 /mnt
sudo rsync -aAXv / --exclude={"/dev/","/proc/","/sys/","/tmp/","/run/","/mnt/","/media/*","/lost+found"} /mnt
  • Install service (steps 3-5 from my previous post, setssdroot.service from top of this post).
  • Copy service files to SSD
sudo cp /etc/systemd/system/setssdroot.service /mnt/etc/systemd/system/setssdroot.service
sudo cp /sbin/setssdroot.sh /mnt/sbin/setssdroot.sh
  • Install software for restoration rootfs (on eMMC). It is possible to reboot back in this rootfs if /etc/setssdroot.conf file is absent.
  • Create file /etc/setssdroot.conf
sudo touch /etc/setssdroot.conf
  • Reboot system. You will boot in new rootfs located in SSD.
    Don’t forget to synchronize /boot/ /lib/modules/ folders with eMMC when moding kernels.
When rootfs on SSD is used, /dev/mmcblk0 is unmounted, so we can backup it with dd.
Rootfs on SDD can be safely backed after loading back into rootfs on eMMC:
sudo mount /dev/mmcblk0p1 /mnt
sudo rm /mnt/etc/setssdroot.conf
reboot
For backups I use SSD drive connected to M.2 key E throught M.2 key E to m.2 key M adapter from aliexpress.
There is another method to mount rootfs on SSD in JetPack 4.4. Now initrd is located with kernel image in /boot/ folder on /dev/mmcblk0p1. Loaded initrd is set in INITRD initrd_file line in /boot/extlinux/extlinux.conf on /dev/mmcblk0p1.
LABEL primary
         MENU LABEL primary kernel
         LINUX /boot/Image
         INITRD /boot/initrd
It’s possible to unpack initrd:
#!/bin/bash
sudo mkdir newinitrd
cd newinitrd
sudo cp /boot/initrd …/initrd
gzip -cd …/initrd | cpio -imd
Now we can change script init to change variable rootdev.
My test variant of init:
#!/bin/bash
initrd_dir=/mnt/initrd;
dhclient_flag=“true”;
count=0;
echo “Starting L4T initial RAM disk” > /dev/kmsg;
#Mount procfs, devfs, sysfs and debugfs
mount -t proc proc /proc
if [ ? -ne 0 ]; then echo "ERROR: mounting proc fail..." > /dev/kmsg; exec /bin/bash; fi; mount -t devtmpfs none /dev if [ ? -ne 0 ]; then
echo “ERROR: mounting dev fail…” > /dev/kmsg;
exec /bin/bash;
fi;
mount -t sysfs sysfs /sys
if [ ? -ne 0 ]; then echo "ERROR: mounting sys fail..." > /dev/kmsg; exec /bin/bash; fi; mount -t debugfs none /sys/kernel/debug/ if [ ? -ne 0 ]; then
echo “ERROR: mounting debugfs fail…” > /dev/kmsg;
exec /bin/bash;
fi;
create reboot command based on sysrq-trigger
if [ -e “/proc/sysrq-trigger” ]; then
echo -e “#!/bin/bash \necho b > /proc/sysrq-trigger;” > /sbin/reboot;
chmod 755 /sbin/reboot;
fi;
ssdroot parameter at extlinux.conf
rootdev="(sed -ne 's/.*\bssdroot=\/dev\/\([abcdefklmnps0-9]*\)\b.*/\1/p' < /proc/cmdline)" if [ "{rootdev}" != “” ]; then
echo “Root from sddroot parameter found: {rootdev}" > /dev/kmsg; fi if [ "{rootdev}” == “” ]; then
real root parameter
rootdev="(sed -ne 's/.*\broot=\/dev\/\([abcdefklmnps0-9]*\)\b.*/\1/p' < /proc/cmdline)" fi if [ "{rootdev}" == “” ]; then
uuid_regex=’[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}’
rootdev="(sed -ne "s/.*\broot=\(PARTUUID={uuid_regex})\b.*/\1/p" < /proc/cmdline)"
fi
if [ “{rootdev}" != "" ]; then echo "Root device found: {rootdev}” > /dev/kmsg;
fi
added branch for nvme
if [[ “{rootdev}" == nvme* ]]; then if [ ! -e "/dev/{rootdev}” ]; then
count=0;
while [ ${count} -lt 50 ]
do
sleep 0.2;
count=expr $count + 1;
if [ -e “/dev/{rootdev}" ]; then break; fi done fi if [ -e "/dev/{rootdev}” ]; then
echo “Found dev node: /dev/{rootdev}" > /dev/kmsg; else echo "ERROR: {rootdev} not found” > /dev/kmsg;
exec /bin/bash;
fi
mount /dev/{rootdev} /mnt/; if [ ? -ne 0 ]; then
echo “ERROR: {rootdev} mount fail..." > /dev/kmsg; exec /bin/bash; fi; elif [[ "{rootdev}” == PARTUUID* ]]; then
count=0;
while [ {count} -lt 50 ]; do sleep 0.2; count="(expr ${count} + 1)"
  mount "${rootdev}" /mnt/;
  if [ $? -eq 0 ]; then
  	break;
  fi
done
mountpoint /mnt/;
if [ ? -ne 0 ]; then echo "ERROR: {rootdev} mount fail…" > /dev/kmsg;
exec /bin/bash;
fi;
elif [[ “{rootdev}" == mmcblk* ]]; then if [ ! -e "/dev/{rootdev}” ]; then
count=0;
do
sleep 0.2;
exec /bin/bash;
fi
echo “ERROR: {rootdev} mount fail..." > /dev/kmsg; exec /bin/bash; fi; elif [[ "{rootdev}” == sd* ]]; then
if [ ! -e “/dev/{rootdev}" ]; then while [ {count} -lt 50 ]
do
sleep 0.2;
exec /bin/bash;
fi
echo “ERROR: {rootdev} mount fail..." > /dev/kmsg; exec /bin/bash; fi; elif [[ "{rootdev}” == “nfs” ]]; then
eth=cat /proc/cmdline | sed 's/.* ip=\([a-z0-9.:]*\) .*/\1/' | awk -F ":" '{print $6}';
echo “Ethernet interface: $eth” > /dev/kmsg;
ipaddr=ifconfig "$eth" | grep -A1 "$eth" | grep "inet addr" | sed 's/.*addr:\([0-9\.]*\) .*/\1/';
if [[ “$ipaddr” =~ [0-9].[0-9].[0-9].[0-9] ]]; then
echo “IP Address: ipaddr" > /dev/kmsg; dhclient_flag="false"; else while [ {count} -lt 50 ]
do
sleep 0.2;
echo “IP Address: $ipaddr” > /dev/kmsg;
dhclient_flag=“false”;
break;
fi
done
fi
if [ “$dhclient_flag” == “true” ]; then
timeout 8s /sbin/dhclient eth; if [ ? -ne 0 ]; then
echo “ERROR: dhclient fail…” > /dev/kmsg;
exec /bin/bash;
fi;
fi;
nfsroot_path=”cat /proc/cmdline | sed -e 's/.*nfsroot=\([^ ,]*\)[ ,].*/\1 /'”;
nfsroot_opts="cat /proc/cmdline | sed -ne 's/.*nfsroot=\([^ ,]*\),\([^ ]*\).*/\2 /p'";
if [[ "{nfsroot_opts}" == "" ]]; then nfsroot_opts="nolock" fi mount -t nfs -o {nfsroot_opts} {nfsroot_path} /mnt/ &>/dev/kmsg; if [ ? -ne 0 ]; then
echo “ERROR: NFS mount fail…” > /dev/kmsg;
exec /bin/bash;
fi;
else
echo “No root-device: Mount failed” > /dev/kmsg;
exec /bin/bash;
fi
echo “Rootfs mounted over ${rootdev}” > /dev/kmsg;
mount -o bind /proc /mnt/proc;
mount -o bind /sys /mnt/sys;
mount -o bind /dev/ /mnt/dev;
cd /mnt;
cp /etc/resolv.conf etc/resolv.conf
echo “Switching from initrd to actual rootfs” > /dev/kmsg;
mount --move . /
exec chroot . /sbin/init 2;
And repack initrd:
#!/bin/bash
find . -print0 | cpio --null --quiet -H newc -o | gzip -9 -n > …/initrdtossd
sudo cp …/initrdtossd /boot/initrdtossd
Now we need to change extlinux.conf to primary boot option and create secondary!!! (uncomment at end of the file).
LABEL primary
         LINUX /boot/Image
         INITRD /boot/initrdtossd
         APPEND {bootargs} ssdroot=/dev/nvme0n1p1
This method is only propoused. I couldn’t make it work yet.
rootdev variable is empty at highlighted line from init, while /proc/cmdline consists string ssdroot=/dev/nvme0n1p1 and /dev/nvme0n1p1 is visible when system boot is stopped in initrd:
rootdev="$(sed -ne ‘s/.\bssdroot=/dev/([abcdefklmnps0-9])\b.*/\1/p’ < /proc/cmdline)"
Any advice?
Just wanted to say, ty so much @crazy_yorick for your work on this thus far. I have one of the new Xavier NX dev kits, and I’m very interested in having the root of the filesystem be on my extremely fast m2 nvme, rather than my extremely slow sd card. Does anyone know if this has been tried on a Xavier NX?
Hello, I would also be very interested, as @erikneffca, to learn how to move the root to an SSD drive of Xavier NX. As soon as I start installing things (e.g. jetson-inference Python library that requires PyTorch), SD card gets saturated. I am new to Jetson community so I tried to apply same procedures that were suggested for other Jetson modules to boot from SSD. However, it seems that the bootloader on NX is different and it didn’t work for me.
Another approach would be to extend root logical volume space with SSD drive, something which is quite straight forward on standard Linux distributions (create group of physical partitions and use LVM to define a volume), but I couldn’t succeed in it with Jetson NX neither.
I would be surprising if NVIDIA expects industrial users to be able to embed all software on a tiny SD card or 16 Gb eMMC. I’ve been working with many ARM and x86 embedded systems and it was always easy to deploy with an SSD (SATA or PCIe). Maybe NVIDIA experts can suggest something as I would expect them to have brainstormed on this.
Have anyone found a solution for this?
I can confirm that the first method does work on Xavier NX Dev Kit - i made it running just yesterday on my NX.
You need to check and adapt the name of the NVMe device (iirc it is /dev/nvme0n1 instead of /dev/nvme0n1p1)
@dkreutz thx for confirming - I’ll give it a try!
I’ve found how to mount SSD as rootfs with extlinux.conf APPEND, but in still requires initrd modification (modification of this method).
Main problem: initrd created by JetPack 4.4 has init script, that search for root device first as device name format, then as PARTUUID format. Then only “PARTUUID*”, “mmcblk*”, “sd*”, “nfs” are acepted as legal rootdev string.
init[62…173]:
rootdev="(sed -ne 's/.*\broot=\/dev\/\([abcdefklmnps0-9]*\)\b.*/\1/p' < /proc/cmdline)" if [ "{rootdev}" == “” ]; then
fi
fi
if [[ “{rootdev}" == PARTUUID* ]]; then ------- elif [[ "{rootdev}” == mmcblk* ]]; then
elif [[ “{rootdev}" == sd* ]]; then ------- elif [[ "{rootdev}” == “nfs” ]]; then
else
exec /bin/bash;
fi
Working second method step by step:
  1. Flash device (Xavier AGX or NX (tested on AGX only)) with JetPack 4.4.
  2. Unpack initrd:
    Create directory in user folder. Create there 2 scripts:
    unpack.sh:
#!/bin/bash
pack.sh:
#!/bin/bash
Make them executable. Create folder to unpack and cd there.
sudo mkdir dir_initrdssd
sudo cp /boot/initrd ./
cd dir_initrdssd
sudo …/unpack.sh
  1. Patch init
    Initrd source will be in dir_initrdssd folder. Patch init script with following patch init.patch:initpatch.log (1.4 KB)
    (only .log text files are accepted by forum :( )
    Patch changes priority to PARTUUID over device name and adds "nvme
    " as accepted rootfs name.
  2. Pack back
sudo …/pack.sh
initrdtossd in folder with scripts will be created. Copy this file to /boot
  1. Edit extlinux.conf
    Find PARTUID of nvme partition with future rootfs.
lsblk -o NAME,PARTUUID
Output needed:
nvme0n1
└─nvme0n1p1 XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX
Open /boot/extlinux/extlinux.conf
sudo gedit /boot/extlinux/extlinux.conf
Add APPEND line to primary boot and create backup boot
Example:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
LINUX /boot/Image
APPEND ${cbootargs} root=PARTUUID=XXXXXXXX-XXXX-XXXX-XXXX->XXXXXXXXXXXX quiet
LABEL backup
MENU LABEL backup kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet
  1. DON’T FORGET to copy rootfs to SSD!!!.
  2. Reboot and PROFIT
P.S. In blockquote “[two points]/” changed to “…/”. I don’t know how to fix it.
@crazy_yorick can you give pros and cons for both methods?
Ok.
Methods:
  1. systemd service
    In this case systemd service setssdroot.service runing before local-fs-pre.target is used ( after systemd-remount-fs.service from initrd, if initrd with systemd is used) . So it’s one of the first runing units when system starts up. But, there are parallel targets swap.target, cryptsetup-pre.target , various low-level services. (systemd bootup ) . This service executes script, which switches rootfs with systemctl call /bin/systemctl --no-block switch-root ${CHROOT_PATH}.
Pros:
  • No initrd or extlinux.conf required. So, work with JetPack 4.2, where kernel is located in special partition.
  • After building new kernel, default initrd update workflow is required, no manual modification of initrd (i.e. flash.sh ...).If system doesn’t use initrd, we need only install modules on SSD and eMMC.
  • If /dev/nvme0n1p1 is absent, default rootfs is used, because setssdroot.service will not be executed.
Cons:
  • It’s still hack:) .
  • There are units, executing in parallel with setssdroot.service, including udevd, thus, for some devices modules will be loaded from rootfs on eMMC while others from NVMe. That’s why we need to install same modules on both.
  • I don’t understand why, but we need copy of setssdroot.service and setssdroot.sh on NVMe, otherwise service completes with error (but still switches rootfs).
  1. extlinux.conf APPEND
    In this case APPEND line with new “root=…” parameter is added to extlinux.conf. At kernel loading stage cboot appends this line to kernel cmdline. So cmdline have 2 “root=…” parameters: first - “root=/dev/mmcblk0p1” from device tree for cboot, second - custom, appended with extlinux.conf directive.
Pros:
  • Normal system bootup sequence. Main and backup kernel could be different.
  • All modules are loaded from initrd or rootfs on NVMe only. One needs only to copy new kernel image and it’s initrd to /boot/ directory on eMMC and configure /boot/extlinux/extlinux.conf there. No modules installation for new kernel on eMMC required. (Except when the same kernel image is used as backup).
  • Backup kernel is set by extlinux.conf :
LABEL backup
LINUX /boot/Image
INITRD /boot/initrd
It can have it’s own initrd and only it’s modules are installed on eMMC.
Cons:
  • Only JetPack 4.4 now is supported, because cboot with extlinux.conf parsing is required.
  • After building new kernel and updating initrd , init script should be patched manualy in case of default JetPack initrd. According @gtj, Dracut generated initrd works without modification
  • If NVMe is absent, linux is stuck in initrd. To boot from backup kernel and rootfs on eMMC command from debug terminal should be used.
Thanks to @crazy_yorick and our friend at JetsonHacks (https://github.com/jetsonhacks/rootOnNVMe),
I was able to seamlessly run provided scripts on a AGX Xavier board today to transfer rootfs on a Crucial P1 500GB M2 NVMe SSD which was available at /dev/nvme0n1p1
Hi everyone,
I was able to use initrd produced by ubuntu for second method ( extlinux.conf APPEND), thus removing manual manipulations with initrd.
Steps:
  2. Add update-initramfs hook to add xusb firmware to initrd.
    a. Create file tegra-xusbfw with following content (Remove log extention tegra-xusbfw.log (306 Bytes) ):
#!/bin/sh
PREREQ=""
prereqs()
echo “$PREREQ”
case $1 in
prereqs)
prereqs
exit 0
esac
. /usr/share/initramfs-tools/hook-functions
copy_exec /lib/firmware/tegra19x_xusb_firmware /lib/firmware
copy_exec /lib/firmware/tegra18x_xusb_firmware /lib/firmware
b. Make file executable and copy to /usr/share/initramfs-tools/hooks directory.
c. Generate initrd:
sudo update-initramfs -c -v -k all
d. Check in log that “tegra19x_xusb_firmware” was added.
e. At this step you should have file initrd.img-4.9.140-tegra in /boot directory.
  1. Edit /boot/extlinux/extlinux.conf
Edit INITRD parameter and add APPEND parameter to primary record. Should be something like this (extlinux.conf.log (383 Bytes) ):
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd.img-4.9.140-tegra
LABEL backup
LINUX /boot/Image
INITRD /boot/initrd
  2. Reboot
Kernel don’t rises any errors while booting from this initrd.
It would be good if someone from NVIDIA check if ubuntu generated initrd didn’t miss any other modules.
It’s very strange that usb firmware is needed to get to an nvme device but if that works, great!
USB firmware is needed because otherwise the usb port will not work.
If you use initrd generated without firmware hook, system do will boot, you will see login screen, but without keyboard it’s useless :).
P.S. I will try APPEND parameter combinations later on weekends.
Yeah but what’s that got to do with nvme unless you’re using a usb<>nvme bridge. I may have gotten lost between this thread and the one on the NX forum. Are you using usb<>nvme or pcie<>nvme?
I use NVMe in M.2 key M slot (PCIe x4).
All above was to differentiate 2 variants of APPEND in extlinux.conf method (2)
2.1 With initrd, installed while flashing with JetPack 4.4.
This case requares patching init script in initrd, as default init script prioritirizes root=/dev/[somedevice] over root=PARTUUID=.... .
With default init APPEND below doesn’t work for some still unknown reason. (Boot stops at initrd’s console, as if there is no device, but I see /dev/nvme0n1p1 there ???)
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/nvme0n1p1
In case
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX
first root=/dev/mmcblk0p1 is prioritirized and system boots to rootfs on eMMC.
2.2 With initrd generated by update-initramfs in ubuntu.
In this case Xavier is flashed with JetPack 4.4, then new initrd is generated on Xavier itself and extlinux.conf edited to point on new initrd and APPEND root=PARTUUID= added.
This initrd lacks xusb firmware, but has no problems with parsing root=xxx parameter. So linux boots to rootfs on NVMe well, but USB ports are not functional, so no mouse or keyboard could be used.
To add xusb firmware, hook is registered (this post) before update-initramfs.
Thus 2.2 method is most traditional from Linux view, IMHO.
