How to boot from text mode
I install jetson OS with SDK manager . the device can boot to graphical desktop normally.
But I use cmd below to set text mode ,failed:
sudo systemctl set-default multi-user.target
after boot ,the screen is black ,can not login to system.
dmesg below:
dmesg | grep hdmi:
[    5.588016] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    6.129586] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    6.141638] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    6.245927] tegradc 15200000.display: hdmi: tmds rate:241699K prod-setting:prod_c_hdmi_223m_300m
[    6.260605] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[    6.535120] tegradc 15200000.display: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[    6.537010] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[    6.592099] tegradc 15200000.display: hdmi: plugged
dmesg|grep error:
[    1.164485] armv8-pmu: probe of arm-pmu failed with error -22
[    8.847325] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    8.853081] imx219: probe of 9-0010 failed with error -121
[    8.866239] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    8.871880] imx219: probe of 10-0010 failed with error -121
version info :
uname -a
Package: nvidia-jetpack
Version: 5.0.1-b118
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 5.0.1-b118), nvidia-opencv (= 5.0.1-b118), nvidia-cudnn8 (= 5.0.1-b118), nvidia-tensorrt (= 5.0.1-b118), nvidia-container (= 5.0.1-b118), nvidia-vpi (= 5.0.1-b118), nvidia-nsight-sys (= 5.0.1-b118), nvidia-l4t-jetson-multimedia-api (>> 34.1-0), nvidia-l4t-jetson-multimedia-api (<< 34.2-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Can you help me how to fix ?thank you .
Jetpack5.0 does not enable framebuffer console for now. So there is no text mode.
Jetpack4.x still supports framebuffer console.
