How to bring up the CAN bus when bootup without manually input of the following?
- sudo modprobe mttcan
- sudo ip link set can0 type can bitrate 1000000
- sudo ifconfig can0 up
Please see this post: [url]Enable CAN Bus on Jetson TX2 - Jetson TX2 - NVIDIA Developer Forums
Just modify with your bitrate in the /etc/network/interfaces file
Ltro
Thanks Ltro,
It works as putting the commands in rc.local. I also find this link is helpful: How to Configure and Use CAN Bus | RidgeRun Developer
