My aim is to use the yolo_v4_object_detection model that is trained in TAO framework and saved in “.hdf5” format to do object detection.
It is giving good results on inferencing inside jupyter notebook.
How can I use one interactive UI to input one image of my choice and
the model will perform object detection and give us back the image with
bounding boxes , class name and confidence score.
Is there any dependencies on TAO framework ?
do I have to use Nvidia platform only, or , I can use any platform.
Basically how do I transfer my model from TAO framework and
integrate it into an interactive UI outside TAO ?
Can I use it directly in “.hdf5” format or do I have to convert it to any other format ?
In summary, I need guidance on converting the model to a compatible format and building an interactive UI to deploy it outside the TAO framework.
I am using the model in “.onnx” format.
I am getting error :
Traceback (most recent call last): File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/inference.py”, line 252, in main() File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py”, line 717, in return_func raise e File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py”, line 705, in return_func return func(*args, **kwargs) File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/inference.py”, line 248, in main raise e File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/inference.py”, line 236, in main inference(args) File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/inference.py”, line 126, in inference os.makedirs(arguments.results_dir) File “/usr/lib/python3.8/os.py”, line 213, in makedirs makedirs(head, exist_ok=exist_ok) File “/usr/lib/python3.8/os.py”, line 213, in makedirs makedirs(head, exist_ok=exist_ok) File “/usr/lib/python3.8/os.py”, line 213, in makedirs makedirs(head, exist_ok=exist_ok) [Previous line repeated 5 more times] File “/usr/lib/python3.8/os.py”, line 223, in makedirs mkdir(name, mode) PermissionError: [Errno 13] Permission denied: ‘/home/ubuntu’ Execution status: FAIL
