How to build Connector Sample in VS2015
I’m trying to build connector sample project in vs2015
I saw the Readme file that ‘Some plumbing is required to support other Visual Studio versions.’
But I can’t find any resources what the required plumbing specifically is.
Does the sentense means that may be “You must use vs2019 for build Connector Sample”?
If not, please notice me that how to build connector sample in vs2015.
Thank you.
When you run build.bat it will automatically pull down a compiler that will work. You don’t need to have Visual Studio installed. I don’t think 2015 will work because we actually set the C++ language standard to C++17.
Oh, I checked that. Thank you!
