How to build self-made ROS packages for Xavier?
I have finished the cross compile for ROS, which is mentioned in the following link.
Then I want to build my own ROS package for Xavier.
I am not sure how to set ROS path in the compile.
Should I use ROS for HOST PC or ROS Crosscompiled?
How to set such parameters in cmake file?
Is there any step by step instructions or examples ?
Hi Liang_Qi,
You can just source setup.bash in the cross compilation path on the host.
What specific parameters? Could you tell more?
You can refer to https://devtalk.nvidia.com/default/topic/1070193/cross-compile-target-file-including-ros-and-driveworks/ shared by other developer.
