Currently I have a custom board with Xavier AGX 32GB and Jetpack 4.6.3.
I have a Linux_for_Tegra folder with my custom image inside and all the needed stuff.
My question is:
In case I would like to burn a new Xavier AGX 64GB, can I do it from the same folder?
Or do I need to make some changes to some files? If so, could please explain me?
I did not want to port a new JetPack to my custom product.
What I was hoping is to be able to burn my custom existing image to a new Xavier AGX 64GB.
Is it possible?
It depends on which jetack version is your “existing image” based on. If it is too old, then it is not possible to flash on new device directly. You need to check if there is any overlay provided in the L4T archive website.
Yes, I don’t have the PCN announcement right now. You can check which jetpack supports that module. If the announcement says jp4.6.3 supports it, then you don’t need any extra software.
Also, it does not matter what image run on your 32GB module. The critical file is not in the image you clone out either.
