How to caculate the deskew value
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes)
My setting serdes_pix_clk_hz is “375000000”
So Output data rate = 375000000 * 10/ 4 = 937.5Mbps.
The output data rate < 1.5 Gbps.So I think the deskew calibration is not required.
But the camera kernel code in the file csi.c:
So the caculate value CLK_HZ_FOR_DESKEW=750MHZ,So Output data rate > 750.According to this caculating,I need the deskew calibration.So how to determine Deskew calibration values?
Should follow below calculation.
Suppose the deskew current is control by RCE firmware depend on below calculation.
According to your description: Output data rate = (sensor or deserializer pixel clock in Hertz) * (bits per pixel) / (number of CSI lanes), then deskew must satisfy the condition:Output data rate > 1.5Gbps. They compare the same type rate. Why does the CLK_HZ_FOR_DESKEW defined in the code need to be divided by 2:
define CLK_HZ_FOR_DESKEW ((150010001000)/2)
Do you confirm this code been run?
Yes,I added some log:
Result:
Judging from the printing, it didn’t run in, so I wonder if there is a problem with the calculation here? The value of pix_clk_hz here is pix_clk_hz=serdes_pixel_clock=375000000HZ, and the judgment condition here should be Output data rate =(sensor or deserializer pixel clock in hertz) *(bits per pixel) /(number of CSI lanes) means Output data rate = 375000000 10/4 = 937.5Mbps. Therefore, the judgment condition pix_clk_hz >= CLK_HZ_FOR_DESKEW should be changed to: pix_clk_hz(bits per pixel) / (number of CSI lanes) >= 1.5Gbps.
Suppose your case don’t need deskew calibration.
Do you just want to clarify these driver or have issue to capture frame data from your sensor?
Yes, I am just determining whether deskew calibration is needed. I can’t get the frame data now. Judging from the source kernel code, the judgment condition for triggering deskew is not based on the calculation formula of Output data rate = (sensor or deserializer pixel clock in Hertz) * (bits per pixel) / (number of CSI lanes).
Have reference to below link to get the trace log.
