How to calculate weights for 360d camera with deepstream dewarp
I’m using deepstream 6.0 to dewarp AXIS M3048-P Network Camera on jetson nano
in example nvidia provided file name "nvaisle_2M.csv " with dozens value
how can i calculate to find out value to fill csv file for any 360d camera ?
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) : Jetson nano
• DeepStream Version : 6.0.0.1
• JetPack Version (valid for Jetson only) : 4.6.1
• TensorRT Version : 8.2.1-1+cuda10.2
• NVIDIA GPU Driver Version (valid for GPU only) : origin from flashed image
• Issue Type( questions, new requirements, bugs) : questions
how can i calibration deepstream-dewarper for new 360d camera ?
For basic dewarp usage, we have provided sample dewarp config files under deepstream-dewarper-test which has all the required parameters to be set for dewarping.
CSV files also consists of the de-warping parameters along with other parameters like local, global co-ordinates, Car entry & exit ROI co-ordinates etc. which are very specific to DS 360d smart garage use-case.Hence for basic de-warping config files (config_dewarper.txt, config_dewarper_perspective.txt) can be referred and its various parameters can be modified based on the use-case and projections to be used.
