how to call an executable file and give the variables
I would like to call an executable file and give it variables in my fortran code. for example:
function obj(ii)
use omp_lib
use  ifport
implicit none
integer,intent(in)::ii
integer::     thron
real::obj
thron=omp_get_thread_num()
obj=RUNQQ('C:\pgi\matlab_omp_cuda\test.exe','')
return
end function  obj
In this code, “thron” is the thread no. which is a variable in another executable file.
Hi Chia,
Could you do something like this?
function obj(ii)
use omp_lib
use  ifport
implicit none
integer::     thron
real::obj
character(len=80) :: cmdline
write (cmdline, '(i1)') thron
obj=RUNQQ('C:\pgi\matlab_omp_cuda\test.exe', trim(cmdline))
return
end function  obj
This modification would basically convert thron to a string, store it in the cmdline variable, then pass the cmdline variable as a parameter to the test.exe application.
However, this assumes that the test.exe application has been coded in such a way as to expect this parameter upon being called, and handle it correctly.
Hope this helps,
+chris
