How to Call Hardware Decoding to Accelerate RTSP Video Reading?
I am using the Jetson AGX Orin and would like to use the YOLO V8 model to detect rtsp videos streams, and then send the detection results to another host. Here is my program. The video delay is very high now. Is there any way to make slight changes to my program and call for hardware accelerated decoding?
def camera1_thread():
    cap1 = cv2.VideoCapture('rtsp://admin:admin123@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1')
    print('camera_channel_1 is running')
    model = YOLO('yolov8n.pt')
    while True:
        ret, frame = cap1.read()
        if ret:
            results = model(frame)
            boxes = results[0].boxes
            type = int(boxes[0].cls[0].tolist())
            conf = round(boxes[0].conf[0].tolist(), 1)
            xywhn = list(map(int, boxes[0].xywhn[0].tolist()[:]))
            data = {
                'address': 'ch1',
                'alarm':type,
                'conf': conf,
                'xyxy': xywhn,
            json_data = json.dumps(data)
            client1.sendall(json_data.encode())
    cap1.release()
Please refer to the sample:
Doesn't work nvv4l2decoder for decoding RTSP in gstreamer + opencv - #3 by DaneLLL
For running Yolo models, we suggest use DeepStream SDK to get optimal performance. Please check the documents:
NVIDIA Metropolis Documentation
Hi DaneLLL!
Thank you for your reply! Sorry to bother you again. I have reviewed the link you sent. May I use “rtspsrc location”= rtsp://…" need to compile opencv with gstreamer? Do you have any relevant tutorials that you can send me? Thank you!
Sorry for the late response.
