Hi Danell,
I tired the 2nd link and added patch to example 10_camera_recording but getting below error.
I have added all possible libs and includes.
Kindly HELP!
I have attached the
a) Code
b) Error
c) Settings
CODE:
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "Error.h"
#include "Thread.h"
#include <gst/gst.h>
#include <gst/app/gstappsrc.h>
#include <gst/base/gstpushsrc.h>
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <EGLStream/NV/ImageNativeBuffer.h>
#include <NvVideoEncoder.h>
#include <NvApplicationProfiler.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <fstream>
#include <iostream>
#include <fstream>
#include "NvCudaProc.h"
using namespace Argus;
using namespace EGLStream;
// Constant configuration.
static const int MAX_ENCODER_FRAMES = 5;
static const int DEFAULT_FPS = 30;
// Configurations which can be overrided by cmdline
static int CAPTURE_TIME = 1; // In seconds.
static Size2D<uint32_t> STREAM_SIZE (640, 480);
static std::string OUTPUT_FILENAME ("output.h264");
static uint32_t ENCODER_PIXFMT = V4L2_PIX_FMT_H264;
static bool DO_STAT = false;
static bool VERBOSE_ENABLE = false;
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define CONSUMER_PRINT(...) printf("CONSUMER: " __VA_ARGS__)
#define CHECK_ERROR(expr) \
do { \
if ((expr) < 0) { \
abort(); \
ORIGINATE_ERROR(#expr " failed"); \
} while (0);
namespace ArgusSamples
* FrameConsumer thread:
* Creates an EGLStream::FrameConsumer object to read frames from the stream
* and create NvBuffers (dmabufs) from acquired frames before providing the
* buffers to V4L2 for video encoding. The encoder will save the encoded
* stream to disk.
class ConsumerThread : public Thread
public:
//explicit ConsumerThread(OutputStream* stream);
explicit ConsumerThread(OutputStream* stream, GstElement *appsrc_);
~ConsumerThread();
bool isInError()
return m_gotError;
private:
/** @name Thread methods */
virtual bool threadInitialize();
virtual bool threadExecute();
virtual bool threadShutdown();
bool createVideoEncoder();
void abort();
static bool encoderCapturePlaneDqCallback(
struct v4l2_buffer *v4l2_buf,
NvBuffer *buffer,
NvBuffer *shared_buffer,
void *arg);
OutputStream* m_stream;
UniqueObj<FrameConsumer> m_consumer;
NvVideoEncoder *m_VideoEncoder;
std::ofstream *m_outputFile;
bool m_gotError;
GstElement *m_appsrc_;
GstClockTime timestamp;
EGLDisplay egl_display;
//ConsumerThread::ConsumerThread(OutputStream* stream) :
ConsumerThread::ConsumerThread(OutputStream* stream, GstElement *appsrc_) :
m_stream(stream),
m_VideoEncoder(NULL),
m_outputFile(NULL),
m_gotError(false),
m_appsrc_(appsrc_),
timestamp(0)
egl_display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
eglInitialize(egl_display, NULL, NULL);
ConsumerThread::~ConsumerThread()
if (m_VideoEncoder)
if (DO_STAT)
m_VideoEncoder->printProfilingStats(std::cout);
delete m_VideoEncoder;
if (m_outputFile)
delete m_outputFile;
eglTerminate(egl_display);
bool ConsumerThread::threadInitialize()
// Create the FrameConsumer.
m_consumer = UniqueObj<FrameConsumer>(FrameConsumer::create(m_stream));
if (!m_consumer)
ORIGINATE_ERROR("Failed to create FrameConsumer");
// Create Video Encoder
if (!createVideoEncoder())
ORIGINATE_ERROR("Failed to create video m_VideoEncoderoder");
// Create output file
m_outputFile = new std::ofstream(OUTPUT_FILENAME.c_str());
if (!m_outputFile)
ORIGINATE_ERROR("Failed to open output file.");
// Stream on
int e = m_VideoEncoder->output_plane.setStreamStatus(true);
if (e < 0)
ORIGINATE_ERROR("Failed to stream on output plane");
e = m_VideoEncoder->capture_plane.setStreamStatus(true);
if (e < 0)
ORIGINATE_ERROR("Failed to stream on capture plane");
// Set video encoder callback
m_VideoEncoder->capture_plane.setDQThreadCallback(encoderCapturePlaneDqCallback);
// startDQThread starts a thread internally which calls the
// encoderCapturePlaneDqCallback whenever a buffer is dequeued
// on the plane
m_VideoEncoder->capture_plane.startDQThread(this);
// Enqueue all the empty capture plane buffers
for (uint32_t i = 0; i < m_VideoEncoder->capture_plane.getNumBuffers(); i++)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane));
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
CHECK_ERROR(m_VideoEncoder->capture_plane.qBuffer(v4l2_buf, NULL));
return true;
bool ConsumerThread::threadExecute()
IStream *iStream = interface_cast<IStream>(m_stream);
IFrameConsumer *iFrameConsumer = interface_cast<IFrameConsumer>(m_consumer);
// Wait until the producer has connected to the stream.
CONSUMER_PRINT("Waiting until producer is connected...\n");
if (iStream->waitUntilConnected() != STATUS_OK)
ORIGINATE_ERROR("Stream failed to connect.");
CONSUMER_PRINT("Producer has connected; continuing.\n");
int bufferIndex;
bufferIndex = 0;
// Keep acquire frames and queue into encoder
while (!m_gotError)
NvBuffer *buffer;
int fd = -1;
// Check if we need dqBuffer first
if (bufferIndex < MAX_ENCODER_FRAMES &&
m_VideoEncoder->output_plane.getNumQueuedBuffers() <
m_VideoEncoder->output_plane.getNumBuffers())
// The queue is not full, no need to dqBuffer
// Prepare buffer index for the following qBuffer
v4l2_buf.index = bufferIndex++;
else
// Output plane full or max outstanding number reached
CHECK_ERROR(m_VideoEncoder->output_plane.dqBuffer(v4l2_buf, &buffer,
NULL, 10));
// Release the frame.
fd = v4l2_buf.m.planes[0].m.fd;
NvBufferDestroy(fd);
if (VERBOSE_ENABLE)
CONSUMER_PRINT("Released frame. %d\n", fd);
// Acquire a frame.
UniqueObj<Frame> frame(iFrameConsumer->acquireFrame());
IFrame *iFrame = interface_cast<IFrame>(frame);
if (!iFrame)
// Send EOS
v4l2_buf.m.planes[0].m.fd = fd;
v4l2_buf.m.planes[0].bytesused = 0;
CHECK_ERROR(m_VideoEncoder->output_plane.qBuffer(v4l2_buf, NULL));
break;
// Get the IImageNativeBuffer extension interface and create the fd.
NV::IImageNativeBuffer *iNativeBuffer =
interface_cast<NV::IImageNativeBuffer>(iFrame->getImage());
if (!iNativeBuffer)
ORIGINATE_ERROR("IImageNativeBuffer not supported by Image.");
fd = iNativeBuffer->createNvBuffer(STREAM_SIZE,
NvBufferColorFormat_YUV420,
//NvBufferLayout_BlockLinear,
NvBufferLayout_Pitch);
if (VERBOSE_ENABLE)
CONSUMER_PRINT("Acquired Frame. %d\n", fd);
EGLImageKHR egl_image = NULL;
egl_image = NvEGLImageFromFd(egl_display, fd);
if (egl_image == NULL)
fprintf(stderr, "Error while mapping dmabuf fd (0x%X) to EGLImage\n",
fd);
HandleEGLImage(&egl_image);
NvDestroyEGLImage(egl_display, egl_image);
// Push the frame into V4L2.
v4l2_buf.m.planes[0].bytesused = 1; // byteused must be non-zero
// Wait till capture plane DQ Thread finishes
// i.e. all the capture plane buffers are dequeued
m_VideoEncoder->capture_plane.waitForDQThread(2000);
CONSUMER_PRINT("Done.\n");
requestShutdown();
return true;
bool ConsumerThread::threadShutdown()
return true;
bool ConsumerThread::createVideoEncoder()
int ret = 0;
m_VideoEncoder = NvVideoEncoder::createVideoEncoder("enc0");
if (!m_VideoEncoder)
ORIGINATE_ERROR("Could not create m_VideoEncoderoder");
if (DO_STAT)
m_VideoEncoder->enableProfiling();
ret = m_VideoEncoder->setCapturePlaneFormat(ENCODER_PIXFMT, STREAM_SIZE.width(),
STREAM_SIZE.height(), 2 * 1024 * 1024);
if (ret < 0)
ORIGINATE_ERROR("Could not set capture plane format");
ret = m_VideoEncoder->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, STREAM_SIZE.width(),
STREAM_SIZE.height());
if (ret < 0)
ORIGINATE_ERROR("Could not set output plane format");
ret = m_VideoEncoder->setBitrate(4 * 1024 * 1024);
if (ret < 0)
ORIGINATE_ERROR("Could not set bitrate");
if (ENCODER_PIXFMT == V4L2_PIX_FMT_H264)
ret = m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H264_PROFILE_HIGH);
else
ret = m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H265_PROFILE_MAIN);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder profile");
ret = m_VideoEncoder->setLevel(V4L2_MPEG_VIDEO_H264_LEVEL_5_0);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder level");
ret = m_VideoEncoder->setRateControlMode(V4L2_MPEG_VIDEO_BITRATE_MODE_CBR);
if (ret < 0)
ORIGINATE_ERROR("Could not set rate control mode");
ret = m_VideoEncoder->setIFrameInterval(30);
if (ret < 0)
ORIGINATE_ERROR("Could not set I-frame interval");
ret = m_VideoEncoder->setFrameRate(30, 1);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder framerate");
ret = m_VideoEncoder->setHWPresetType(V4L2_ENC_HW_PRESET_ULTRAFAST);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder HW Preset");
// Query, Export and Map the output plane buffers so that we can read
// raw data into the buffers
ret = m_VideoEncoder->output_plane.setupPlane(V4L2_MEMORY_DMABUF, 10, true, false);
if (ret < 0)
ORIGINATE_ERROR("Could not setup output plane");
// Query, Export and Map the output plane buffers so that we can write
// m_VideoEncoderoded data from the buffers
ret = m_VideoEncoder->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 10, true, false);
if (ret < 0)
ORIGINATE_ERROR("Could not setup capture plane");
printf("create video encoder return true\n");
return true;
void ConsumerThread::abort()
m_VideoEncoder->abort();
m_gotError = true;
bool ConsumerThread::encoderCapturePlaneDqCallback(struct v4l2_buffer *v4l2_buf,
NvBuffer * buffer,
NvBuffer * shared_buffer,
void *arg)
ConsumerThread *thiz = (ConsumerThread*)arg;
if (!v4l2_buf)
thiz->abort();
ORIGINATE_ERROR("Failed to dequeue buffer from encoder capture plane");
#if 1
if (buffer->planes[0].bytesused > 0)
GstBuffer *gstbuf;
GstMapInfo map = {0};
GstFlowReturn ret;
gstbuf = gst_buffer_new_allocate (NULL, buffer->planes[0].bytesused, NULL);
gstbuf->pts = thiz->timestamp;
thiz->timestamp += 33333333; // ns
gst_buffer_map (gstbuf, &map, GST_MAP_WRITE);
memcpy(map.data, buffer->planes[0].data , buffer->planes[0].bytesused);
gst_buffer_unmap(gstbuf, &map);
g_signal_emit_by_name (thiz->m_appsrc_, "push-buffer", gstbuf, &ret);
gst_buffer_unref(gstbuf);
else
gst_app_src_end_of_stream((GstAppSrc *)thiz->m_appsrc_);
sleep(1);
#else
thiz->m_outputFile->write((char *) buffer->planes[0].data,
#endif
if (thiz->m_VideoEncoder->capture_plane.qBuffer(*v4l2_buf, NULL) < 0)
thiz->abort();
ORIGINATE_ERROR("Failed to enqueue buffer to encoder capture plane");
return false;
// GOT EOS from m_VideoEncoderoder. Stop dqthread.
if (buffer->planes[0].bytesused == 0)
CONSUMER_PRINT("Got EOS, exiting...\n");
return false;
return true;
* Argus Producer thread:
* Opens the Argus camera driver, creates an OutputStream to output to a
* FrameConsumer, then performs repeating capture requests for CAPTURE_TIME
* seconds before closing the producer and Argus driver.
static bool execute()
GMainLoop *main_loop;
GstPipeline *gst_pipeline = NULL;
GError *err = NULL;
GstElement *appsrc_;
gst_init (0, NULL);
main_loop = g_main_loop_new (NULL, FALSE);
char launch_string_[1024];
sprintf(launch_string_,
"appsrc name=mysource ! video/x-h264,width=%d,height=%d,stream-format=byte-stream !",
STREAM_SIZE.width(), STREAM_SIZE.height());
sprintf(launch_string_ + strlen(launch_string_),
" h264parse ! qtmux ! filesink location=a.mp4 ");
gst_pipeline = (GstPipeline*)gst_parse_launch(launch_string_, &err);
appsrc_ = gst_bin_get_by_name(GST_BIN(gst_pipeline), "mysource");
gst_app_src_set_stream_type(GST_APP_SRC(appsrc_), GST_APP_STREAM_TYPE_STREAM);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_PLAYING);
// Create the CameraProvider object and get the core interface.
UniqueObj<CameraProvider> cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to create CameraProvider");
// Get the camera devices.
std::vector<CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
ORIGINATE_ERROR("No cameras available");
// Create the capture session using the first device and get the core interface.
UniqueObj<CaptureSession> captureSession(
iCameraProvider->createCaptureSession(cameraDevices[0]));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to get ICaptureSession interface");
// Create the OutputStream.
PRODUCER_PRINT("Creating output stream\n");
UniqueObj<OutputStreamSettings> streamSettings(iCaptureSession->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings = interface_cast<IOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to get IOutputStreamSettings interface");
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(STREAM_SIZE);
UniqueObj<OutputStream> outputStream(iCaptureSession->createOutputStream(streamSettings.get()));
// Launch the FrameConsumer thread to consume frames from the OutputStream.
PRODUCER_PRINT("Launching consumer thread\n");
ConsumerThread frameConsumerThread(outputStream.get(), appsrc_);
//ConsumerThread frameConsumerThread(outputStream.get());
PROPAGATE_ERROR(frameConsumerThread.initialize());
// Wait until the consumer is connected to the stream.
PROPAGATE_ERROR(frameConsumerThread.waitRunning());
// Create capture request and enable output stream.
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(outputStream.get());
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(iRequest->getSourceSettings());
if (!iSourceSettings)
ORIGINATE_ERROR("Failed to get ISourceSettings interface");
iSourceSettings->setFrameDurationRange(Range<uint64_t>(1e9/DEFAULT_FPS));
// Submit capture requests.
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat capture request");
// Wait for CAPTURE_TIME seconds.
for (int i = 0; i < CAPTURE_TIME && !frameConsumerThread.isInError(); i++)
sleep(1);
// Stop the repeating request and wait for idle.
iCaptureSession->stopRepeat();
iCaptureSession->waitForIdle();
// Destroy the output stream to end the consumer thread.
outputStream.reset();
// Wait for the consumer thread to complete.
PROPAGATE_ERROR(frameConsumerThread.shutdown());
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(gst_pipeline));
g_main_loop_unref(main_loop);
gst_deinit();
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
static void printHelp()
printf("Usage: camera_recording [OPTIONS]\n"
"Options:\n"
" -r Set output resolution WxH [Default 640x480]\n"
" -f Set output filename [Default output.h264]\n"
" -t Set encoder type H264 or H265 [Default H264]\n"
" -d Set capture duration [Default 5 seconds]\n"
" -s Enable profiling\n"
" -v Enable verbose message\n"
" -h Print this help\n");
static bool parseCmdline(int argc, char **argv)
int c, w, h;
bool haveFilename = false;
while ((c = getopt(argc, argv, "r:f:t:d:s::v::h")) != -1)
switch (c)
case 'r':
if (sscanf(optarg, "%dx%d", &w, &h) != 2)
return false;
STREAM_SIZE.width() = w;
STREAM_SIZE.height() = h;
break;
case 'f':
OUTPUT_FILENAME = optarg;
haveFilename = true;
break;
case 't':
if (strcmp(optarg, "H264") == 0)
else if (strcmp(optarg, "H265") == 0)
ENCODER_PIXFMT = V4L2_PIX_FMT_H265;
if (!haveFilename)
OUTPUT_FILENAME = "output.h265";
else
return false;
break;
case 'd':
CAPTURE_TIME = atoi(optarg);
break;
case 's':
DO_STAT = true;
break;
case 'v':
VERBOSE_ENABLE = true;
break;
default:
return false;
return true;
int main(int argc, char *argv[])
if (!parseCmdline(argc, argv))
printHelp();
return EXIT_FAILURE;
NvApplicationProfiler &profiler = NvApplicationProfiler::getProfilerInstance();
if (!ArgusSamples::execute())
profiler.stop();
profiler.printProfilerData(std::cout);
return EXIT_SUCCESS;
ERROR
Building target: gstreamerTest01
Invoking: NVCC Linker
/usr/local/cuda-9.0/bin/nvcc --cudart static -L/usr/lib/aarch64-linux-gnu -L/usr/local/cuda/targets/aarch64-linux/lib -L/usr/lib/aarch64-linux-gnu/tegra --relocatable-device-code=false -link -o "gstreamerTest01" ./main.o ./main1.o ./common/NvAnalysis.o ./common/NvApplicationProfiler.o ./common/NvBuffer.o ./common/NvCudaProc.o ./common/NvDrmRenderer.o ./common/NvEglRenderer.o ./common/NvElement.o ./common/NvElementProfiler.o ./common/NvJpegDecoder.o ./common/NvJpegEncoder.o ./common/NvLogging.o ./common/NvUtils.o ./common/NvV4l2Element.o ./common/NvV4l2ElementPlane.o ./common/NvVideoConverter.o ./common/NvVideoDecoder.o ./common/NvVideoEncoder.o ./common/Thread.o -lgstreamer-1.0 -lgstbadvideo-1.0 -lgstbadbase-1.0 -lgstbadaudio-1.0 -lgstreamer-0.10 -lnvjpeg -lnvosd -lnvbuf_utils -lX11 -lGLESv2 -lEGL -lv4l2 -lcudart -lcuda -ldrm -largus -lnveglstream_camconsumer -lpthread -lgobject-2.0 -lglib-2.0
./main.o: In function `ArgusSamples::ConsumerThread::encoderCapturePlaneDqCallback(v4l2_buffer*, NvBuffer*, NvBuffer*, void*)':
makefile:59: recipe for target 'gstreamerTest01' failed
make: Leaving directory '/home/nvidia/Desktop/aasim/Gstreamer1/Debug'
/home/nvidia/Desktop/aasim/Gstreamer1/Debug/../main.cpp:431: undefined reference to `gst_app_src_end_of_stream'
./main.o: In function `ArgusSamples::execute()':
/home/nvidia/Desktop/aasim/Gstreamer1/Debug/../main.cpp:481: undefined reference to `gst_app_src_get_type'
/home/nvidia/Desktop/aasim/Gstreamer1/Debug/../main.cpp:481: undefined reference to `gst_app_src_set_stream_type'
collect2: error: ld returned 1 exit status
make: *** [gstreamerTest01] Error 1
> Shell Completed (exit code = 2)
SETTINGS:
INCLUDES----->
/usr/include/gstreamer-1.0
/usr/include/aarch64-linux-gnu
/home/nvidia/tegra_multimedia_api/samples/common/classes
/home/nvidia/tegra_multimedia_api/include/libjpeg-8b
/usr/include/libdrm/
/home/nvidia/tegra_multimedia_api/samples/common/algorithm/cuda
/home/nvidia/tegra_multimedia_api/argus/samples/utils
/usr/include/gstreamer-1.0/gst/
/usr/include/gstreamer-1.0/gst/app
/usr/include/glib-2.0
/usr/lib/x86_64-linux-gnu/glib-2.0/include
LIBS---->
gstreamer-1.0
gstbadvideo-1.0
gstbadbase-1.0
gstbadaudio-1.0
gstreamer-0.10
nvjpeg
nvosd
nvbuf_utils
X11
GLESv2
EGL
v4l2
cudart
cuda
drm
argus
pthread
gobject-2.0
glib-2.0
