I have an Orin NX 16G module, and an IIC device connected to board.
I want to capture the power button pressed signal when it going to power off, so i can terminate the IIC device properly.
How can i capture the power button pressed signal?
Looking for reply, thanks!
$ cat /usr/local/bin/shutdown_button_monitor.sh
#!/bin/sh
# ansible managed
# systemd-logind prints a line of the form
# Dez 21 11:12:10 box03.yeepa.de systemd-logind[748]: Power key pressed.
# on key press, but doesn't handle the button because gnome3 blocks systemd from doing so.
# See `systemd-inhibit` for that.
# first sleep a minute so we have chance to disable this scritp if it runs amok
sleep 1m
# so we workaround gnome a bit here.
journalctl -u systemd-logind --follow --lines=0 | \
while read line ; do
if echo "$line" | grep --quiet 'Power key pressed'
then
systemctl poweroff
fi
done
and the service file that starts / restarts it
$ cat /etc/systemd/system/shutdown_button_monitor.service
# ansible managed
[Unit]
Description=Power off the machine if the power button is pressed
# Workaround for gnomes block of the shutdown button
# https://unix.stackexchange.com/questions/242129/gnome-3-how-to-set-power-button-to-shutdown-instead-of-suspend#242452
# Monitor these blocks yourself with `systemd-inhibit`
[Service]
User=root
ExecStart=/usr/local/bin/shutdown_button_monitor.sh
Restart=always
RestartSec=5
[Install]
WantedBy=multi-user.target
