hi,
for image_meta_test.c sample, how can i change another path which is not locally to store photoes?
thank you
hi,
thank you
You can use the fileNameImg parameter of NvDsObjEncUsrArgs.
Ex.
NvDsObjEncUsrArgs userData = { 0 };
/* To be set by user */
userData.saveImg = save_img;
userData.attachUsrMeta = attach_user_meta;
userData.fileNameImg = “myfile.jpg”
hi,
when i use this:
it shows error when i make:
deepstream_image_meta_test.c: In function ‘pgie_src_pad_buffer_probe’:
deepstream_image_meta_test.c:253:30: error: assignment to expression with array type
and another error is below when i use dummy_object for full frame save:
WARNING from element nvvideo-renderer: A lot of buffers are being dropped.
Warning: A lot of buffers are being dropped.
^C
thank you very much!
Sorry, please use below sample instead:
sprintf (userData.fileNameImg,"myfile.jpg");
it is good, thank you very much!
