**• Hardware Platform (Jetson / GPU) : Jetson Nano
• DeepStream Version : Deepstream 4.0.1 SDK
• JetPack Version (valid for Jetson only) : 4.2.2
• TensorRT Version :
: deepstream_sdk_v4.0.1_jetson/sources/apps/apps-common/src
: Due to the camera delay problem in IP Camera, the delay speed problem was improved when changing from H.264 format to MJPEG format.
However, after using the MJPEG format, the jetson board stops and ends as the memory increases due to a memory leak problem.
It seems that DeespStream 4.0.1 is holding the nvjpegdec decoder. I want to use nvv4l2decoder, can I change the decoder inside the code?
When debugging, it seems to run with nvjpecdec set.
I think nvjpecdec, omx, nvv4l2decoder can be interchanged with each other.
I think I will have a hard time setting up my application to migrate to DeepStream 5.0.
So, I want to know how to change the decoder from DeepStream4.0.1 SDK to source code.
And I need something to get some info about the SDK c code. Is it there?
