How to change DP data format from rgb to yuv422
Hi
we need DP data format yuv422, but the default value is rgb.
We support the mode in HDR video playback but it is currently broken:
Render YUV422 10bit to 10 bits monitor on Orin NX - #11 by DaneLLL
We are checking it and will update.
i run demo sucess,
but DP still send RGB format data to display
You are correct. Now only RGB mode is supported on Orin series. HDR mode doesn’t work.
