How to change filename of Azure payload
I am unsure on how to set the filename of the json payload that is sent to Azure IOT. Check out the imgur link: Currently the file placed in the blob storage are named randomly(?).
https://imgur.com/a/qbcuGkl
I believe that there is no option to do so within Azure IoT itself. Only the option of changing the pathing of payload data is given.
https://social.msdn.microsoft.com/Forums/en-US/c48e0f5f-f7ff-47df-a8f7-83ffe534c461/unsure-on-how-to-rename-incoming-json-file-before-storing-it-in-blob-storage?forum=azureiothub
Changing of payload filename is not given in the config files(only topic/key/value). It is handled in gst-nvmsgconv? Hoping for a hint.
relevant config files:
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM   - Custom schema payload
msg-conv-payload-type=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_azure_proto.so
msg-broker-config=cfg_azure.txt
#topic=mytopic
#Optional:
Note that libnvds_azure_proto is used. cfg_azure.txt contains my connection string.
Present payload route: Jetson Nano->Azure IotHub->Azure Stream Analytics->Azure blob storage
I believe that the SQL language used in Stream analytics only deals/filters the data within the json file.
Thank you
We have verified the case on DS4.0.1:
https://devtalk.nvidia.com/default/topic/1063540/deepstream-sdk/nvmsgbroker-kafka-fixed-port-9092-/post/5387568/#5387568
If you are on DS4.0, please upgrade to DS4.0.1 and try again.
