I would like to change the object data after nvtracker and pass the updated metadata to seconadry classier.
Can you suggest me the way for that???
In running deepstream-app. you can put the logic in gie_processing_done_buf_prob() in
deepstream_sdk_v4.0.2_jetson\sources\apps\sample_apps\deepstream-app\deepstream_app.c
For accessing metadata, you can refer to nvinfer_src_pad_buffer_probe() in
deepstream_sdk_v4.0.2_jetson\sources\apps\sample_apps\deepstream-gst-metadata-test
Questions:
1.As per my knowledge object id’s are allocated after tracker. gie_processing_done_buf_prob() gives output of pgie i need data after tracker. How to access that ??
2.I have tried creating source probe from tracker get data data and change it there and using sink probe i have tried giving input to sgie1. but it is not working??
Do i need to create custom plunging between them and apply my logic there ??
Please suggest the correct way…
Please check
* Buffer probe function after tracker.
static GstPadProbeReturn
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
