Hi team, I am using R35.2.1 on xavier nx module, custom currier board. I flashed the os on nvme disk, now pcie link up on gen3 , I want to know how to change PCIE3.0’s De-emphasis to -3.5dB ? where can I modify in the kernel ? and how ?
root@w:~# lspci -s 0005:01:00.0
0005:01:00.0 Non-Volatile memory controller: Device 0000:8111 (rev 01)
root@w:~#
root@w:~#
root@w:~# lspci -s 0005:01:00.0 -vv | grep LnkSta
LnkSta: Speed 8GT/s (ok), Width x4 (ok)
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
root@w:~#
root@w:~# dmesg | grep "0005:01:00"
[ 4.809080] pci 0005:01:00.0: [0000:8111] type 00 class 0x010802
[ 4.809514] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 4.821266] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 4.822633] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 4.833886] nvme 0005:01:00.0: Adding to iommu group 6
[ 4.839151] nvme nvme0: pci function 0005:01:00.0
[ 4.842189] nvme 0005:01:00.0: enabling device (0000 -> 0002)
root@w:~#
root@w:~#
root@w:~# dmesg | grep "141a0000.pcie"
[ 4.646376] tegra194-pcie 141a0000.pcie: Adding to iommu group 6
[ 4.655402] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.656617] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.665564] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.673919] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 4.791740] tegra194-pcie 141a0000.pcie: Link up
[ 4.794488] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
