I have a Jetson Nano with 16 gb emmc and a carrier board from waveshare. I want controll a ultrasonic sensor with pin 21and 22 and need a 10us trigger signal. So I need 100kHz and I get only 16kHz which I just measured with the oscilloscope. I tried also other pins with clock funktion but have the same result.
yes I am using the 40 pin expansion and didn’t update the pinmux spreadsheet.
I tried the jetson_io.py but it crashes immediately. I read that third party carrier boards doesnt support jetson_io.py.
do you have documentation about the pinmux spreadsheet?
And which pins would your prefer to controll one ultrasonic sensor, one micro servo and three tiny vibration motors. All of them are connected to an external power unit I need just the signal pins.
that’s correct, Jetson-IO only support with developer kits.
please refer to developer guide. Pinmux Changes to change the pinmux configuration applied by the software.
