Yes it works. But this method is not suitable for me. I don’t want change default *.cfg files, because its add complexity to patching SDK. I just want to change pinmux regs in the CBoot runtime as it does when the Linux kernel boots.
Hello.
I used bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg and “Xavier Series SoC Technical Reference Manual” (for check) to get addresses. Also, I found macros NV_ADDRESS_MAP_PADCTL_A0_BASE in CBoot code that evaluates as padctl regs base address (0x2430000).
For example, reg PADCTL_UART_SPI1_SCK_0 (GPIO Z3) have offset 0x40 in PADCTL_A13 (0x0243d000), then I get the full address using expression NV_ADDRESS_MAP_PADCTL_A0_BASE + 0xd040.
you should also refer to public release sources,
i.e. $L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/cboot/bootloader/partner/common/drivers/gpio/tegrabl_gpio.c
instead of using NV_WRITE32 to program GPIO directly.
you may check this internal function to get register address.
for example,
furthermore,
you should only using the GPIO pin number to access GPIOs.
please use these Tegra GPIO driver APIs in CBoot. for example, tegrabl_gpio_read(), and tegrabl_gpio_write().
thanks
To access the GPIO I am using this CBoot driver as you mentioned. But unfortunately the function call gpio_config(gpio_main_drv, TEGRA_GPIO(Z, 3), GPIO_PINMODE_OUTPUT) does not change the pin direction from default input to output.
Instead, I found that pinmux configuration for MB1 in .cfg file works well. But this solution does not suit me.
this looks incorrect,
you may also refer to the GPIO header file for Xavier series, i.e. tegra194-gpio.h ,
please have a try by using… TEGRA194_MAIN_GPIO(Z, 3) for confirmation,
thanks
There is no definition of the TEGRA194_MAIN_GPIO in the CBoot sources for 32.5.1. Check with grep -r TEGRA194_MAIN_GPIO in the source directory.
TEGRA_GPIO works as needed with tegrabl_gpio_read() and tegrabl_gpio_write() functions. I checked this with oscilloscope with pinmux configured in MB1.
let’s back to your original question,
may I know what’s the actual use-case to change the pinmux settings for those 4 GPIOs/pins in CBoot.
could you please also share diff file to indicate all the cboot changes you’ve done for reference.
thanks
The patch in the attachment contains in general all the changes that were made. A line NV_WRITE32(NV_ADDRESS_MAP_PADCTL_A0_BASE + 0x0028, 0x0000000a); leads to the error described in the 1st post.
please use the 32-bit register write marco in the NV_WRITE32(), you may also read it back and print it out to ensure you’ve gotten the correct register.
you’re not seeing it changes, perhaps you’re doing this before GPIO/pinmux initialization from the core DTSI files.
